Old 05-03-2004, 20:05   #1 (permalink)
Member: 847
Thanks Meter: 35
6310i contact service
Hi, all.
Got contact service on 6310i
Can this be caused by wrong flashing ?
Regards
Sjakie
Run test with Prodigy.
phone name: 6310i
Phone IMEI: 3511092086xxxxx
Phone SW: V 5.51 08-07-03 NPL-1 (c) NMP.
Generation: DCT4
Test results from phone startup log:
ST_UEM_CBUS_IF_TEST - PASSED
ST_EAR_DATA_LOOP_TEST - PASSED
ST_TX_IDP_LOOP_TEST - NO SIGNAL
ST_TX_IQ_DP_LOOP_TEST - NO SIGNAL
ST_SIM_CLK_LOOP_TEST - PASSED
ST_SIM_IO_CTRL_LOOP_TEST - PASSED
ST_IR_LOOP_TEST - PASSED
ST_MBUS_RX_TX_LOOP_TEST - PASSED
ST_BACKUP_BATT_TEST - PASSED
ST_WARRANTY_TEST - PASSED
ST_SIM_LOCK_TEST - PASSED
ST_PPM_VALIDITY_TEST - PASSED
ST_KEYBOARD_STUCK_TEST - PASSED
ST_LCD_TEST - PASSED
ST_LPRF_IF_TEST - PASSED
ST_LPRF_AUDIO_LINES_TEST - PASSED
ST_FLASH_CHECKSUM_TEST - PASSED
ST_IR_IF_TEST - NOT EXECUTED
Old 05-03-2004, 22:35   #2 (permalink)
Member: 44658
try to flash phone, upgrade/down grade software...
Imei rebuild?
if all fails, looking at UEM/UPP
Old 05-03-2004, 23:42   #3 (permalink)
Member: 3260
check this link, you will find answer for your question there...
http://www.telempire.com/forum/showt...&threadid=2293
Old 05-04-2004, 10:33   #4 (permalink)
Member: 847
Thanks Meter: 35
Hi, thanks for reply.
How too rebuild imei, would like to try that first.
before UEM hardware.
Regards
Sjakie
Old 05-04-2004, 10:36   #5 (permalink)
Member: 3260
That's not worth of, you will only loose time and money for RPL calculation.
Your problem is HW, not SW.
Change UEM, write RPL and enjoy
WBR
gsm5ko
Old 05-04-2004, 12:11   #6 (permalink)
Member: 847
Thanks Meter: 35
Hi,
When connected too flasher i can power on.
I tried *#warranty* code .
There serial number is given 351488-20-816886-6
On programm read out
IMEI : 351109-20-861480-4
So theres a mismatch, is this the cause ?
regards
Sjakie
Old 05-04-2004, 12:52   #7 (permalink)
Member: 3260
No.
Somebody wrote PMM area from different phone only.
Why do you waste time ?
Your problem is here:
It means signals between UPP and UEM are broken.
Change UEM !
I repaired approx. 10 phones with this fault.
WBR
gsm5ko
Old 05-04-2004, 14:30   #8 (permalink)
Member: 847
Thanks Meter: 35
Hi, gsm5ko
Think your right, did a little of reheating and imei turned ???????????.
But this UEM is gleud, think will be hell to change it.
regards
Sjakie
Old 05-04-2004, 15:13   #9 (permalink)
Member: 3260
This is another problem
WBR
gsm5ko
Old 05-04-2004, 21:27   #10 (permalink)
Member: 847
Thanks Meter: 35
Thanks for info.
Id better scrap the board
Regards
Sjakie
6310i contact service emmerdale Nokia Digital Core Technology 4 ( DCT-4 ) 20 12-07-2006 08:41
6310i contact service Ciubaka Nokia Digital Core Technology 4 ( DCT-4 ) 1 06-23-2004 12:18
6310i contact service deejayzak Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-27-2003 21:02
6310i contact service ... MrHazeem Nokia Digital Core Technology 4 ( DCT-4 ) 4 02-25-2003 19:08
6310i Contact Service ikarus Nokia Digital Core Technology 4 ( DCT-4 ) 5 01-23-2003 12:49
Page generated in 0.35536 seconds with 8 queries
