07-04-2004, 10:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Crazy House Age: 41
Member: 27606 Status: Offline Thanks Meter: 15 | 2 x 6210 network problem second gets network but sometimes when I wan't to have a call network is gone. I didn't do anything with it so I wiil change PA and can i do thing like in 3310,8210 with antenna switch with two little wires |
07-04-2004, 23:10 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: romania Age: 42
Member: 57035 Status: Offline Thanks Meter: 70 | Yes the trick with the "little two wires" works on 6210 you can do that to exclude the antena switch fault . Clean antena conectors/ resold ( CHANGE ) PA ! on the second one ! If it doesn't work try to resold with flux ( CHANGE ) the IF IC ! GOOD LUCK ! |
07-05-2004, 02:09 | #3 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @Destructor Most proper fault on your 6210's in this case is your COBBA pads. The COBBA on the 6210 have a serous flaw in print circuit layout. The grounding leg to the COBBA very often oxidize due to the fact that it is not proper soldered from factory and by time it oxidize and will loose connection. Have seen this fault on scores of 6210. Check COBBA and let us know if it's this fault. Regards |
07-28-2005, 20:22 | #5 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: Romania Age: 48
Member: 109294 Status: Offline Thanks Meter: 22 | Hi 2 U all!! Quote:
Cheers! Oh, i forgot, I noticed that COBBA has a LOT of pins grounded. Which one R U talking about? | |
6210 network problem pls help | Surej | Nokia Hardware & Hardware Repair | 2 | 01-16-2003 10:54 |
6210 network problem | patrynio | Nokia Hardware & Hardware Repair | 4 | 01-13-2003 13:06 |
Nokia 3330 and 6210 network problem | tgsm | Nokia Hardware & Hardware Repair | 7 | 10-12-2002 01:38 |
6210 network problem | DJ_Andy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2002 16:27 |
6210 network problem | MadPhone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-19-2001 22:07 |
