6310i half keypad Hi! I have one 6310i with strange problem. Only 1,2,3 keys are working, phone turns on ok. When phone is turned on, it beeps as keys are pressed. Is there any solution?! Please help! Thanks to all in advance! |
HI,, check that key buffer Z300 to each key pad , and work with careful, becasue it near MAD ! Willy |
i got 6310 i , all Button;s r workin excpet 0 # and * , help me out in this , plz Thanks , |
Hi i'm new on this forum but i repair phones since 4 years... so if You have a problem with 6310 if i was You, i try this trick: take a multimeter set in to meansure a PN (diode) and + connect to gnd phone (anything metal) and a - connector connect to all contacts on pcb (keyboard contacts) multimeter should show You a value between 300 - 700 if doesn't ther is a trouble. rehot Z300 (danger! it's near MAD) if ok then ok... if not take off Z300 clear pcb and check connections to keyboard if it's ok then rehot z300 if still nothing - change Z300 if still nothing i think it's a MAD or connections between Z300 and MAD |
hi , i m new in hardware i m delain with software , kindly tell me about z300 plz explain all the thing above in detail . thanks . |
