12-16-2003, 17:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: Boro Age: 37
Member: 2461 Status: Offline Thanks Meter: 22 | 6310i N0 Signal.!! Have resoldered it back on. But still no signal Compared it to a working 6310i and there is NO resistance between the 2 x top antenna spring connections. The bottom connection seems to read to other parts of the circuit etc , but the top spring connector doesnt go anywhere Can anyone tell me where the top aerial spring connection goes to on the circuit board so I could put a link wire to it Any advice greatly appreciated B.Rgds John... Last edited by N/East Unlocker; 12-17-2003 at 23:55. |
12-18-2003, 17:01 | #4 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | 6310i Hi Do a manual search and see if you find a network if so try changing P.A. If no network found do as shans said and try changing antenna switch Later D. |
12-19-2003, 18:10 | #6 (permalink) |
Member: 12660 Status: Offline Thanks Meter: 7 | Antenna Switch Hi N/East Unlocker They have different antenna switches you can bridge out the antenna switch with a piece of wire as a temporary solution look around the net/old posts for info then you can do this to check if you get signal then you can replace the antenna switch. Later D. |
[HELP] 6310i no signal and now CONTACT SERVICE | André_F | Nokia Hardware & Hardware Repair | 3 | 09-05-2006 20:03 |
6310i Poor Signal | sasko2 | Nokia Hardware & Hardware Repair | 3 | 05-29-2005 15:47 |
6310i strange signal problem | gsm_style | Nokia Hardware & Hardware Repair | 5 | 10-13-2004 04:03 |
6310i no signal, who can repair this for me | gsm_style | Nokia Hardware & Hardware Repair | 1 | 04-03-2004 09:08 |
6310i drops signal | tompepper | Nokia Hardware & Hardware Repair | 9 | 01-27-2004 10:42 |
