Old 04-28-2004, 09:57   #1 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
6310i only works in 900 only
What can be the problem??
Regards
Old 04-28-2004, 10:01   #2 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Have you tryed to check the antenna switch?
Try also to search manually for networks and if you find only 900 change the ant. switch.
You can use a switch from 3310 but you will loose the 1900 band.
Old 04-28-2004, 10:16   #3 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
Thanks for quick reply, i will test and post results.
Best regads
I have this phone. Psoible to do that work in 900 mhz? stylius Infinity-Box 8 07-01-2008 23:10
E316 work in 900-1800MHz Mickey Mouse Trident/AGERE Platform 55 08-08-2007 13:36
z10v only works in 900? gabriel148 UST Pro II 0 07-04-2006 15:21
SL45 handsfree only works in one side? eddyb Siemens Hardware Repair Area 0 04-17-2004 23:39
Page generated in 0.23225 seconds with 8 queries
