06-11-2005, 09:44 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 40
Member: 79641 Status: Offline Thanks Meter: 6 | 6310i Signal problem |
06-11-2005, 12:17 | #4 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @adeel786 You have a hardware problem. Most properly its a broken Antenna swicth according to your description of the fault. If the phone cannot find your T-mobile network in manual search it means that the antenna swicth only finds network on one band (900 or 1800/1900 MHZ) Either change it or take it to somebody who can. Regards |
06-11-2005, 12:56 | #7 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @adeel786 Well in this case the phone finds all networks -> means Antenna swicth is ok. This particular fault is your PA (Power Amplifier) which have to be changed. Am I right when I say that when you select the network it gives you the error "Access Denied" ? If so, then it's the PA 100% Regards |
11-15-2005, 15:16 | #9 (permalink) |
Major Poster Join Date: Jun 2005 Location: Africa Age: 56
Member: 153324 Status: Offline Thanks Meter: 1 | Hi everyone, I have a 6310i which worked only on a specific network in Nigeria. Then I flashed it and now it no longer can detect any network. I flashed it with version 5.52 |
nokia 6310i signal problem | allservice | Nokia Hardware & Hardware Repair | 10 | 07-20-2012 14:42 |
6310i weird signal problem??? | Bugsy2006 | Nokia Hardware & Hardware Repair | 2 | 02-24-2007 17:26 |
Nokia 6310i Signal Problem and Turns off | adeel786 | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 06-24-2006 12:23 |
6310i signal problem | gsm_style | Nokia Hardware & Hardware Repair | 3 | 11-18-2004 17:13 |
6310i strange signal problem | gsm_style | Nokia Hardware & Hardware Repair | 5 | 10-13-2004 04:03 |
