03-02-2004, 20:32 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | V153 is dual FET transistor with 6 pins it lies just below the LED under the SIM reader, It is the BIAS current source of the external MIC. I dont know if it's ture the A5 connection or not , but I supposed this cause it is the only Genio(31:0) wich is connected in 2 points with V153 ( Geino2 to pins 6,5 according to schematic ) but when I mesure pin 6 is not connected to pin5 , pin 6 is the Geino-2. All of this because Geino-27 is not founded on all over the schematics !! May be somebody with raised UPP can add something ?? |
03-11-2004, 19:51 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | It's ok. I don't think A5 is used at all. I left a jumper wire in place of A5 out of UPP just in case I might be able to locate it at a later time. Tried flashing, and phone is working still... with jumper wire from UPP connected to nothing (at the moment) |
6300 chinaphone maic solution line cut | giann_yabes2000 | Chinese Models & Cloned Phones | 0 | 01-12-2010 07:49 |
6310i black lines on LCD | RafalTK | Nokia Hardware & Hardware Repair | 6 | 07-29-2009 20:00 |
T880 line 2 cant end/cut calls | hans salim | Infinity-Box | 5 | 11-20-2008 04:43 |
s55 ... other boot line cutted off :( how to unlock ???? | Brka | E-Gold Based Phones | 0 | 07-10-2003 02:04 |
Tip for repairing cut CPU lines | Scaramouche | Nokia Hardware & Hardware Repair | 3 | 12-19-2002 09:35 |
