Old 09-11-2008, 08:45   #1 (permalink)
Member: 574119
Thanks Meter: 29
Arrow 6500 classsic not charging
I have 6500 clasic working all o.k. Except charging i replaced the charging connector strip(usb type )but same problem i dont have schematic and dont know where charging circuit and i.c. Is pls anyone help in this regard thanx
Old 09-11-2008, 09:07   #2 (permalink)
Member: 858825
u change charging iic
The Following User Says Thank You to robinsjohn For This Useful Post:
Old 09-11-2008, 10:14   #3 (permalink)
ucokmonalisa's Avatar
Member: 527741
Thanks Meter: 355
try change
-battery
-conector charger
or try here
Nokia 8600 Luna USB charging
OK guys here is some more technical details on USB charging issues for Nokia 8600 Luna:
- after USB charging specification device is not allowed to draw power from the USB bus if PC suspends the bus. So when you connect USB, there is a little communication going on between PC and Nokia 8600 Luna. That's why you see the initiating of charging. But then the charging stops -> this is because there was no data exchanged between the device and PC and PC decided to suspend device to save power.
- USB charging in Nokia 8600 Luna (charging from the PC's USB port) was not designed as a full charging solution. It is done in order to support the battery power when phone is in data mode (transferring data), so that the battery does not discharge too quickly. The charge load you will get is less then 100mA.
- If the battery is completely depleted or if the phone is power off state, you won't be able to charge with USB data cable. Nokia 8600 Luna will power up, detect that this is not the AC charger and power down again. This behavior might be changed in the future SW release by allowing a limited 100mA charge load in power down state.
Comclusion:
Please use always AC charger to charge your Nokia 8600 Luna, because the USB charging from the PC is just to support the battery when the phone is transferring data.
B.R
ucokmonalisa
The Following User Says Thank You to ucokmonalisa For This Useful Post:
Old 09-11-2008, 10:53   #4 (permalink)
Member: 574119
Thanks Meter: 29
mr .i dont have diagram dont know circuit where charging i.c. Is
Old 02-24-2009, 22:36   #5 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
well, i have one 8600 , when i plug charger , on display start blinking always "Charging".
what this could be, any ideas?
Old 03-23-2009, 19:55   #6 (permalink)
Member: 442749
Thanks Meter: 16
you people need to open the phone and just fix the charging ribbon properly with connectors, and then the problem will be solved.
Old 03-23-2009, 20:24   #7 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
Old 03-23-2009, 22:08   #8 (permalink)
hamada-almasry's Avatar
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,181
Old 03-23-2009, 22:11   #9 (permalink)
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,181
The Following User Says Thank You to hamada-almasry For This Useful Post:
Old 03-25-2009, 11:31   #10 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
always use charger that can handle 500mA consumption.
some chinese "original" chargers can handle just 300mA.
Old 01-26-2010, 18:28   #11 (permalink)
Member: 109508
what is with this offtopic? :| i thought this is a thread for 6500 classic not slide:| so stop it!
3660 not charging help plz dj.comcell WD2 & APE (Symbian Phones) 0 03-29-2010 14:08
6500s not charging armendi04 Nokia Base Band 5 ( BB-5 ) 2 06-10-2009 13:45
Nokia 6500 slide not charging ufo_all Nokia Base Band 5 ( BB-5 ) 0 04-21-2009 11:09
6500s not charging solutions muzamalshahzad Nokia Hardware & Hardware Repair 1 03-15-2009 09:42
Nokia 6500 MIC and Charging Not Supported Urgent Paavalan Nokia Hardware & Hardware Repair 0 03-12-2008 08:04
Page generated in 0.42557 seconds with 8 queries
