Old 06-25-2008, 10:10   #1 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
6500s bluetooth problem
6500s bluetooth on but cant send files
any solution?
The Following User Says Thank You to shachash For This Useful Post:
Old 06-25-2008, 19:04   #2 (permalink)
Member: 761110
Sonork: 100 0911
Thanks Meter: 45
why don't u change the bt module sir?
Old 06-26-2008, 09:06   #3 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
reheet the bt ic..........................
The Following 6 Users Say Thank You to R@jusat For This Useful Post:
Old 06-26-2008, 09:11   #4 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
try to flash the phone first using latest version ....if not work after flash ..... try to repair bt module
Old 06-26-2008, 09:12   #5 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
where is the bt ic, anyone can post pic?
Old 06-26-2008, 09:16   #6 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
any solution?
did u check this saving memmory?
Old 06-26-2008, 09:21   #7 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
what wrong withit........u cn't sent or ca't receive?
Old 06-26-2008, 09:35   #8 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
sometime its sending and sometime its not but 90% not
Old 06-26-2008, 11:58   #9 (permalink)
Member: 580482
any solution?
format ur mmc and format ur mobile 100/
solution
Old 08-26-2008, 18:20   #10 (permalink)
Member: 615701
Thanks Meter: 9
I also this problem any one can help me ? pls send diagrame to post.
thank
The Following User Says Thank You to soksovann For This Useful Post:
Old 08-26-2008, 19:11   #11 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
Old 08-29-2008, 16:35   #12 (permalink)
Member: 615701
Thanks Meter: 9
Yes i has been do it but it same problem !
Old 08-29-2008, 16:42   #13 (permalink)
Member: 615701
Thanks Meter: 9
Yes i has been do it but it same problem ! Can you send the pictre to me ?
Old 08-29-2008, 19:11   #14 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
format with jaf file system if not done then update mobile softwear
http://mea.nokia.com/support/6500slide
Old 08-29-2008, 20:49   #15 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
change blutooth ic ur problum solved
6500 screen problem! clarion_83 Nokia Hardware & Hardware Repair 1 06-05-2008 01:05
6500 Classic Problem magic_d Nokia Base Band 5 ( BB-5 ) 2 05-25-2008 08:19
Who can help me with Nokia 6500S Camera problem? Dream Asia Nokia Hardware & Hardware Repair 0 05-08-2008 11:04
d500 screen problem and bluetooth problem postman bat SWIFT Platform 1 09-03-2006 01:14
Nokia 6230 bluetooth problem not the same problem as others... sharkie2006 Nokia Hardware & Hardware Repair 5 04-16-2006 23:23
Page generated in 0.27526 seconds with 10 queries
