-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   6500s bluetooth problem (http://forum.gsmhosting.com/vbb/f148/6500s-bluetooth-problem-556041/)
shachash 06-25-2008 11:10
6500s bluetooth on but cant send files
any solution?
nilkamal 06-25-2008 20:04
why don't u change the bt module sir?
[email protected] 06-26-2008 10:06
reheet the bt ic..........................
aiyon_861 06-26-2008 10:11
try to flash the phone first using latest version ....if not work after flash ..... try to repair bt module
shachash 06-26-2008 10:12
where is the bt ic, anyone can post pic?
pupaji 06-26-2008 10:16
any solution?
did u check this saving memmory?
pupaji 06-26-2008 10:21
what wrong withit........u cn't sent or ca't receive?
shachash 06-26-2008 10:35
sometime its sending and sometime its not but 90% not
earnest 06-26-2008 12:58
any solution?
format ur mmc and format ur mobile 100/
solution
soksovann 08-26-2008 19:20
I also this problem any one can help me ? pls send diagrame to post.
thank
azez.sd 08-26-2008 20:11
soksovann 08-29-2008 17:35
Yes i has been do it but it same problem !
soksovann 08-29-2008 17:42
Yes i has been do it but it same problem ! Can you send the pictre to me ?
sopnil 08-29-2008 20:11
format with jaf file system if not done then update mobile softwear
http://mea.nokia.com/support/6500slide
[email protected] 08-29-2008 21:49
change blutooth ic ur problum solved
Page generated in 0.26099 seconds with 5 queries
