04-03-2012, 13:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: ??????
Member: 446199 Status: Offline Thanks Meter: 40 | 6500s flashing error... UFS HWK 1ST BOOT : C0,07 [Rm-240] [2.2.0.1] CMT ASICID: 000000010000022600010006010C192101003000 EM 1 ID : 00000295 EM 2 ID : 00000B22 CMT PUBID : 14C00008E2DE8B5651EA2D98CB66A776E88AC9A8 CMT MODE : 00 CMT HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : A69838E8C5F20150E64E2E6E06DE6E50B26B593F CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm240__10.00.mcusw ERASE Skipped DATA_BLK_ERROR at: 0x00400400, 00 ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000, Time: 12:00 Process Failed, Repowering Mobile Mx key MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0821114 Using device: HTI, FW ver: 00.50, SN: 00002774 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14C00008E2DE8B5651EA2D98CB66A776E88AC9A8 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F TransmissionMode: DDR&TX2 Processing MCU file: rm240__10.00.mcusw [BB5,BB5 ALGORITHM] size: 20.39 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 21.87 MB CMT FLASH,NOR area [00000000-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [01480000-015FFFFF] CMT FLASH,NOR area [00140000-0147FFFF] erased in 18.016 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: A69838E8 [RAP Certificate 84 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent ERROR: Packet Error(0xAA), code 0xCB000003 Error while programming [00] at 0x003E0400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 03 00 00 CB Does any 1 know wats the problem? |
04-03-2012, 16:12 | #2 (permalink) |
Freak Poster Join Date: Dec 2007 Location: G.S.Telecom(Lambra)
Member: 667436 Status: Offline Thanks Meter: 154 | this kind of problem comes when RX2 pin is missing so if you want to flash with HWK then try it with other good quality fbus cable ,clean pin outs ,or usb flashing with mx key ,usb had no rx2 |
04-04-2012, 11:08 | #8 (permalink) | ||
Member: 446199 Status: Offline Thanks Meter: 40 | Quote:
This is really going to bug me ..... i am going crazy over here (may be its the Heat) | ||
04-04-2012, 12:50 | #11 (permalink) |
Member: 667436 Status: Offline Thanks Meter: 154 | can you tell me that you are using mx box as interface or flashing with nokia usb rome i suggest nokia usb rom 2nd did you connected your box to a usb hub |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
