Old 03-26-2009, 09:27   #1 (permalink)
Member: 830767
Thanks Meter: 9
6500s keypad not working 0 & 8
help me pleace
Old 03-26-2009, 10:12   #2 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 822
change keypad ic................................
Old 03-26-2009, 10:23   #3 (permalink)
Member: 758126
Thanks Meter: 27
help me pleace
Try this solution
http://i41.tinypic.com/am4j5s.jpg
The Following 4 Users Say Thank You to Posna For This Useful Post:
Old 03-26-2009, 10:50   #4 (permalink)
Member: 645970
Thanks Meter: 157
did you try to change keypad ic... change keypad ic..
Old 03-26-2009, 12:19   #5 (permalink)
Member: 830767
Thanks Meter: 9
Originally Posted by Posna View Post
ease solution but not working for me
Old 04-25-2009, 08:02   #6 (permalink)
karnataka's Avatar
Member: 161943
Sonork: 100.1609577
Thanks Meter: 7
6500s
help me pleace
check the coil behind the bottom key pad flex remove the plastic supporter of key pad and check
Old 06-11-2009, 16:50   #7 (permalink)
Member: 579346
Thanks Meter: 20
i have 6500s key * 0 # not working. I have change ic but the same problem
help me pleace
Old 06-11-2009, 17:02   #8 (permalink)
Bloedman's Avatar
Member: 67905
Thanks Meter: 17
Check connector, resolder connector.
cya
Old 06-11-2009, 17:15   #9 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
help me pleace
hello bro maybe the line from CPU is broken,so need jumper but the ic is Double is hard to replace!!!
br
joni_yang
Old 06-14-2009, 00:18   #10 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
hi mate 1st check keypad connector...after that change ur keypad and then check if problam still same then change keypad ic near the keypad connecter...ur peoblam will solve..post result
Old 06-16-2009, 20:38   #11 (permalink)
Member: 209148
Thanks Meter: 9
help me pleace
make jumper from L2412 To C2414
Old 06-16-2009, 22:13   #12 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 49
You can Try this link
Old 08-02-2010, 16:19   #13 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
I Know the Problem
Do This
සිංහල අය මෙහි සිටීද?????
The Following 2 Users Say Thank You to wasangaama For This Useful Post:
Old 05-07-2011, 23:14   #14 (permalink)
Cracker Jack's Avatar
Member: 858049
Thanks Meter: 31
..........................good.................... .......
Old 07-25-2011, 13:28   #15 (permalink)
Member: 979007
Thanks Meter: 3
plz help nokia 6500s key *#0
6500s keypad not working Hasan7770626 Nokia Hardware & Hardware Repair 18 07-01-2011 07:12
6500s, keypad not working 1,4,7,*,0,# YOJANMACIER Nokia Hardware & Hardware Repair 4 06-06-2009 11:49
6500s keypad not working koucuph Nokia Base Band 5 ( BB-5 ) 0 05-29-2009 01:28
6500s keypad not working alika1972 Nokia Base Band 5 ( BB-5 ) 1 04-29-2009 12:19
Page generated in 0.28152 seconds with 9 queries
