Old 06-24-2008, 08:07   #1 (permalink)
Member: 335851
Thanks Meter: 9
6500s memory card problem
I have a problem with 6500s with memory card problem I tried to replace a battery cover its the same thing plz help me.
Old 10-18-2008, 18:55   #2 (permalink)
Member: 778357
bro chang the cristal ic
Old 10-18-2008, 20:27   #3 (permalink)
Member: 39208
Thanks Meter: 150
push battery cover hard and try!
check switch under battery cover!
Byte
Old 10-18-2008, 23:51   #4 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Byte
Yes you are right man,I've seen many 6500s headsets having this problem,It's an issue of this phone...If you keep pressing the phone reads the card...
Old 10-19-2008, 19:20   #5 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Glass IC must be changed on wather or shock damaged phones...
Old 11-06-2009, 11:11   #6 (permalink)
Bastaphone's Avatar
Member: 385881
Thanks Meter: 40
mmc driver problem if memory card not formatted and format failed. tested
Old 11-06-2009, 12:20   #7 (permalink)
Member: 487070
Thanks Meter: 14
dear bro i have this type of problems many time and my experence is u have to first check memory holder side u have to seen one small luck ,first u haveto push up by small screw if not solve then u have to do another thing bestof luck.
Old 11-06-2009, 12:35   #8 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 964
this problem is comes if the battery cover is lose see and push it and tight the battery cover
Old 11-06-2009, 20:02   #9 (permalink)
Member: 1135448
Sonork: afride
Thanks Meter: 4
u need to left memory card jacket or check it touch with the cover or not
Nokia 6500 slide memory card problem sdimitris Nokia Hardware & Hardware Repair 40 10-01-2011 22:07
6500s memory card crupet problem Afzal Chiri Nokia Hardware & Hardware Repair 0 01-23-2010 09:48
6500s memory card help benz21 Nokia Hardware & Hardware Repair 0 11-04-2008 18:30
NOKIA 6500s MEMORY CARD CORRUPTED GELANEROB Nokia Base Band 5 ( BB-5 ) 0 09-02-2008 05:45
Page generated in 0.34099 seconds with 8 queries
