09-12-2011, 17:44 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | 6500S No Network Problem Also Some Times Shows 3G In Signal Bar But Mostly No Signal. If Any Body Recovered Or Have Any Tested Solution Plz Help Me. I Will Be Grateful............ |
09-12-2011, 18:57 | #2 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Hellooooooooooooooooooooooooooo Any Body Will Help Me Plzzzzzzzzzzzz.......... | |
09-12-2011, 21:11 | #5 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | bro this type problem i well solved change antna switch ic change...............but one thing manuly serch get operators but no acess if serch dien't get any operators then problem is pa...............or get but did not acess switch ic problem................ |
09-13-2011, 17:39 | #7 (permalink) | |
Antina Jumper Possible For This fone???? If Yes How???? | |
09-15-2011, 09:06 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | what about rx for gsm.........search manually and check is ur set reading gsm networks or not? if reading so its TX problem with gsm transmitter in this case 1st replace r7503 and check if same then replace PA (n7520) if still same then replace RF ic (n7505)............... if not reading any network then 1st check x7800(EXT ANT SOCKET) 2nd PA 3rd RF IC ........... check band selection in ur unit try flashing also some time PM make this problem..........post reply Last edited by imran zafar; 09-15-2011 at 09:12. |
09-15-2011, 09:19 | #10 (permalink) | |
But If You Dont Mind Can You Upload Any Image With Step By Step Help. I Am Not Genius Like You. You Are Really A GSM Genius. Thanks Again..... | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
