Old 11-20-2003, 14:28   #1 (permalink)
hyper_wamir's Avatar
Member: 9398
6510 no ringtone
gud evening mates
any help?
tried fixin it by software, it didnt help...
and ideas???
tnx in advance
wamir
Old 11-20-2003, 18:02   #2 (permalink)
Member: 44386
hi,u can try those three resister below the buzzer or check out the buzzer function or not?
Old 11-20-2003, 20:49   #3 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
shek software first
Old 11-20-2003, 21:21   #4 (permalink)
Member: 39601
Thanks Meter: 13
Try useing prodigy box to perform ring test feature at 1st, If it gives sound that means that hardware is good.
Old 11-24-2003, 02:01   #5 (permalink)
Member: 7062
Thanks Meter: 126
its from the four way capistor under the ringer or from the feeding four way capistor beside the uem remmber the 8210 no mic same if not frfom sourcee capistor ll b frfom feeding capistors
this if not software..
thx
Old 11-27-2003, 17:48   #6 (permalink)
Member: 45082
Greetings! How it is possible in N6510 to remove melodies with which has filled?
Old 11-27-2003, 18:24   #7 (permalink)
Member: 764
First check the resistance of the buzzer. Anythink higher that short circuit means bad buzzer...change it
Old 11-27-2003, 22:33   #8 (permalink)
Member: 39601
Thanks Meter: 13
@renda..
The buzzer is a "speacker" with metalic cone, It's internal resistance is about 16 Ohm.
That metalic cone gets the tone of it around 1-3 Khz of the Audio
spectrum waves.
Old 11-28-2003, 02:55   #9 (permalink)
Member: 764
Thanks :-) but I know it, I only tryed to make it as simple as possible for check. By the way buzzer is not a speaker(only very similar function),but it is surely electrodynamic changer. When you measure its resistance it is only a real value of its impedance. Because impedance has its real and complex part as well.
Old 04-06-2004, 20:35   #10 (permalink)
blue1's Avatar
Member: 60613
did you try change buz?\
or a full flash could help?
6510 No charging. evicsson Nokia Hardware & Hardware Repair 4 03-06-2005 02:22
9210i no profile no ringtones no apps no office application how to repair mobilemafia Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 01-18-2005 08:45
Siemens S40: no ringtone, no operator name, no inbox message! NEED GOOD SOLUTION! Scorpic NON Siemens Brand (ODM Phones) 3 05-16-2003 13:00
Nokia 6510 no swith ON only charging! NSerN Nokia Hardware & Hardware Repair 3 10-05-2002 15:55
8310 6510 5210 ringtone stenny Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-26-2002 17:10
Page generated in 0.18595 seconds with 10 queries
