Old 02-07-2004, 13:47   #1 (permalink)
Member: 1341
Unhappy 9210i CS - COBBA SERIAL FAULT
9210i Contact Service
I had one piece of 9210i with CS...
NokiaTest checked phone and write Cobba serial FAULT.
So I changed cobba..and result was the same...
Then I try to flash by Griffin - nothing change...
NokiaTool 1.8 can't change imei or calculate FAID....
After all this phone after insert battery without pressing key show CS on the
front display...and big display inside boot normaly...
Could be problem in MAD LINDA???
Can someone help me with this....
Thanx
REpro
[email protected]
PS: on my board missing D354(32mb flash...)... is it correct???
Old 02-08-2004, 11:13   #2 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
try to flash with griffin. I have repaired two pcs with it. eep tools dont help me in this model
Old 02-10-2004, 02:01   #3 (permalink)
Member: 45635
Thanks Meter: 20
9210 contact service
it is not necessary to be software fault , may be ccont....
Old 02-10-2004, 12:35   #4 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
ccont? you may say COBBA
Old 02-10-2004, 19:27   #5 (permalink)
cairo_gsm's Avatar
Member: 9963
Sonork: 100.65331
Thanks Meter: 216
hi,
try to desolder Cobba and read the 9210 cs fault if cobba serial this mean it is problem from MAD , if the error change to be cobba pararell
this means the cobba is bad or not solderd good
try to but a new one
Old 02-10-2004, 19:27   #6 (permalink)
Member: 1341
Cobba...
Thanx for post...
As I wrote I change COBBA with new one....but result was the same...
Then I try to flash with GRIFFIN...same result... CONTACT SERVICE...
and COBBA SERIAL FAULT
MAybe something with PCB....
REpro
Old 02-10-2004, 19:29   #7 (permalink)
cairo_gsm's Avatar
Member: 9963
Sonork: 100.65331
Thanks Meter: 216
try to read fault with out any cobba inside, it is important to know the fault
Old 02-10-2004, 19:33   #8 (permalink)
Member: 1341
I should try to take out COBBA and check FAULT...
Then I post result...
Repro
Old 04-22-2004, 23:50   #9 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
good idea cairo_gsm... could we use it with all other nokia models?
@repraky: cobba could be OK... but sometimes I have changed cobba 3 times for get a good cobba (there is a lot of defective units in market)
b.r.
Cobba serial or parallel zaenalfaruqi05 Nokia Hardware & Hardware Repair 4 07-11-2005 14:48
COBBA serial ,,COBBA parallel hanoon Nokia Hardware & Hardware Repair 2 02-03-2002 06:10
COBBA serial Faild hanoon Nokia Hardware & Hardware Repair 4 01-28-2002 06:42
8890 cobba serial = *FAILED* bluelights Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-20-2002 20:13
Page generated in 0.22785 seconds with 10 queries
