01-09-2006, 19:09 | #1 (permalink) |
Banned Join Date: Dec 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 51
Member: 101683 Status: Offline Thanks Meter: 26 | 6600 with big problem!!! i have 6600 when i set the ring tone at voice tone, and when any ore ring on me after 2 or 3 ringes it swith to original tone (nokia tone) ,i change the memory card but the same problem,and flash it with another virgen but no way the same problem, any idea to this problem??? thankes to all...... |
01-09-2006, 20:42 | #3 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: BHARAT
Member: 212545 Status: Offline Sonork: 100.1669621 Thanks Meter: 5 | Quote:
use code -*#7370# after you get security code after security code your set get to re start after 15 sec your problem will be removed | |
01-09-2006, 21:06 | #4 (permalink) |
Junior Member Join Date: Oct 2005 Age: 43
Member: 187930 Status: Offline Thanks Meter: 1 | that is the solution erase 4 flash ic's with address method or using erase files then reflash it with high version such as v5.35 ui setting write good pm init sim locks format ua twice it will work ok best regard... |
01-09-2006, 21:19 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | Hey Guys Its So Simple Just Copy Urs Voice Ringtone In Folder Name Sounds/digitel Folder In Mmc @ .:Javajohn:. MOBILEWALA TEAM |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
need help for simtel 6199 with big problem | sartaj | Infinity-Box | 2 | 08-09-2008 21:44 |
6600 with audio problem | momosbabe | WD2 & APE (Symbian Phones) | 3 | 01-13-2007 11:08 |
Sl45i With Big Problem Please Help Anyone!! | robbiesl42 | x1x to x45/x50 | 3 | 03-08-2003 15:05 |
