6600 bt & galary not working :confused::confused:hi bro my 6600 blue tooth is not workin& gallary is not opening:confused::confused::confused: |
reheat bluetooth ic brother |
rehot bluetooth module. |
first get on phone with sim card.then type *#2820# you will see bt adress of your phone. if bt adress is empty you have problem with bt module. 1- just change bt ic on bt module , it looks like 3310 flash ic but not same 2-still have same problem, then change other 2 ic on bt module 3-i have no time: change bt module the second type problem is with software or with mmc socket and mmc card. it is tested by me if bt adres is not empty then 1-full flashing+ui settings+format user area+rp bt 2-still have same problem then you check it without mmc card, then check mmc card socket ways. |
yes it's hardwere rehot or change bluetooth module & be careful cpu under him. |
