Old 01-13-2009, 15:27   #1 (permalink)
Member: 687840
Thanks Meter: 12
6600 bt & galary not working
hi
bro my 6600 blue tooth is not workin& gallary is not opening
Old 01-13-2009, 15:33   #2 (permalink)
SilentHawk's Avatar
Member: 444805
Thanks Meter: 45
reheat bluetooth ic brother
Old 01-13-2009, 15:36   #3 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
rehot bluetooth module.
Old 01-13-2009, 15:42   #4 (permalink)
Member: 581178
Thanks Meter: 438
first get on phone with sim card.then type *#2820#
you will see bt adress of your phone. if bt adress is empty you have problem with bt module.
1- just change bt ic on bt module , it looks like 3310 flash ic but not same
2-still have same problem, then change other 2 ic on bt module
3-i have no time: change bt module
the second type problem is with software or with mmc socket and mmc card. it is tested by me if bt adres is not empty then
1-full flashing+ui settings+format user area+rp bt
2-still have same problem then you check it without mmc card, then check mmc card socket ways.
Old 01-13-2009, 17:51   #5 (permalink)
techno-gsm's Avatar
Member: 776884
Sonork: techno-gsm
Thanks Meter: 152
yes it's hardwere rehot or change bluetooth module & be careful cpu under him.
Nokia N95 BT and Wifi not working pepik Nokia Hardware & Hardware Repair 10 11-17-2012 16:47
2112 ringar & spik & mic not work pizzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz z punitdodiya Nokia Hardware & Hardware Repair 1 09-16-2009 13:48
6600 menu and camera not working kprajeesh4u Nokia Hardware & Hardware Repair 6 05-26-2007 09:32
6600 changed BT twice but not work BT and not open gallery!!! majidjony WD2 & APE (Symbian Phones) 7 09-10-2006 14:29
6600 *,#,c keys not working 47eleven-t Nokia Hardware & Hardware Repair 5 01-18-2005 17:29
Page generated in 0.19452 seconds with 9 queries
