12-30-2007, 11:28 | #1 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 390359 Status: Offline Thanks Meter: 30 | 6600 bt problem %99 solution:) you will see bt adress of your phone. if bt adress is empty you have problem with bt module. 1- just change bt ic on bt module , it looks like 3310 flash ic but not same 2-still have same problem, then change other 2 ic on bt module 3-i have no time: change bt module the second type problem is with software or with mmc socket and mmc card. it is tested by me if bt adres is not empty then 1-full flashing+ui settings+format user area+rp bt 2-still have same problem then you check it without mmc card, then check mmc card socket ways. |
06-04-2008, 16:34 | #9 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: albania
Member: 133415 Status: Offline Thanks Meter: 46 | Quote:
6600 bt problem | Amit Tank | WD2 & APE (Symbian Phones) | 0 | 07-24-2007 15:00 |
6600 BT problem Changed No use...... | sharaz191 | Nokia Hardware & Hardware Repair | 8 | 02-24-2007 03:44 |
6600 BT problem | lood | WD2 & APE (Symbian Phones) | 3 | 07-15-2006 15:56 |
6600 BT problem | lood | Nokia Hardware & Hardware Repair | 3 | 06-27-2006 15:55 |
