6600 contact retailer i alresdy flash the, but it cannot format when i power the phone it says start up failed contact retailer.. solution for this?.. thx.. |
HAI FRIEND ur fault in soved in ufs click "user farmet area" or menual formet "prees *+3+green button(calling button)+ on/off switch" you see in display " formetting" after formettihg all fault is solve...........try & re play me |
ei, try to format manually |
still the same the format cannot finish |
try to rehot the ram ic ,i think it is responsible with that matter..... thanks and more power |
pls reply what ever the result is. thanks,, |
flash it with higher version file on twister. and aloww it to boot finish when you click reboot in normal mode. Dont remove the phone untill it says "insert sim" |
agent lia, do u know whether twister downloading site using twister accsess key is okay |
my 6600 says phone start up failed contact retailer. any one suggestion with out flashing....... |
heat ram & uem & flash it with upgrade version if not solve, reball this ic's & flash is only the solution. i had done it before & day before yesterday too. best of luck.http:///ubb/icons/icon14.gif........http:///ubb/biggrin.gif |
which ram which ram to heat there are 4 of them,which 1 be specific |
@sygnal nobody can fix the problem in this thread...no one match with each other..... so try to use search option ...you will get best solution wbr... |
6600 keep on restarting -> format once with *+[+3 after that contact retailer and then once again done flashing with UFSx now phone keep on restarting within 5to10 seconds |
