Old 04-07-2006, 17:26   #1 (permalink)
simtech's Avatar
Member: 247228
Thanks Meter: 130
6600 contect retiller
Contect retiler its a sw or hw complant, how can i solve pls help me
Old 04-07-2006, 17:33   #2 (permalink)
Member: 94090
Thanks Meter: 26
1-Try Format user area with any box as twister,tornado,........etc
2-try format manually
if it doesn't accept formatting,so it's hardware problem.
Old 04-07-2006, 17:41   #3 (permalink)
TURNING POINT's Avatar
Member: 71721
Sonork: 100.106320
Thanks Meter: 139
dear
contact retailer may comes from both hardware and software
so u try to format user area first manually(press bottom
*,3 and ok(call)bottom and power on your phone(without simcard) then phone shows formating
after formating check
if not ok then full flash your phone (erase first)
write pm
format user area
uisettings
check again or again go for manual formating
also check this thread http://forum.gsmhosting.com/vbb/show...ntact+retailer
if not ok then post result with screen shots
The Following User Says Thank You to TURNING POINT For This Useful Post:
Old 04-09-2006, 08:07   #4 (permalink)
simtech's Avatar
Member: 247228
Thanks Meter: 130
Nice solution
Dear= i first erase all memory chip &flashed again write pm then i format by code now all ok good working so thanks for ur neet explanation (9500,9300.)formating code. C+shift+f press without battery at time put batery wl starting formating. Thank u.
N73 showing contect retiler....... arfanskg MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:25
6600 phone start up failed contect the retailer bharatg Nokia Hardware & Hardware Repair 20 04-01-2008 11:19
Nokia 6600 contect retailer service after flash aukonline MT-BOX 3 11-21-2007 15:05
6600 COntect retailer paklink Griffin 6 03-08-2006 02:38
Page generated in 0.13665 seconds with 10 queries
