06-28-2007, 09:46 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Lahore, Pakistan
Member: 234653 Status: Offline Thanks Meter: 83 | 6600 keypad i have already format the phone with *+3+send plz send me solution with pic thank you |
The Following User Says Thank You to hafizjee For This Useful Post: |
06-28-2007, 09:54 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | clean ui connector (if needed resold) , clean or replace keyboard assy if same problem then reflow two keypad esd filters near ui connector I repaired many 6600 keypad problem like this post result |
06-29-2007, 06:19 | #7 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | hi bro, at 1st change keypad panel, if not ok then check the connector between the board amd keypad panel, if not ok reflow two keypad ic near ui connector,if not ok change them, it will be ok my dear best of luck jimmy |
06-29-2007, 06:22 | #8 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 51
Member: 137671 Status: Offline Thanks Meter: 8 | try to format ur memory card mate.. maybe uve formatted the phone and theres an applications on the memory card that cnt be read by the phone.. thats why the menu is not opening hope this help |
6600 Keypad LED On But LCD no LED+no display | s1emens | Nokia Hardware & Hardware Repair | 9 | 05-28-2009 20:34 |
Nokia 6600 keypad prob. Both IC's replaced and keypad works for only few hours. HELP! | dizzu | Nokia Hardware & Hardware Repair | 4 | 10-17-2005 08:32 |
6600 keypad not work | kardelen gsm | WD2 & APE (Symbian Phones) | 2 | 05-09-2005 22:57 |
6600 keypad not work | kardelen gsm | Nokia Hardware & Hardware Repair | 6 | 05-03-2005 12:57 |
6600 keypad problem | Keke | Nokia Hardware & Hardware Repair | 21 | 01-25-2005 20:49 |
