02-26-2008, 08:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 301177 Status: Offline Thanks Meter: 91 | 6600 keypad print damage |
02-26-2008, 09:48 | #4 (permalink) |
Junior Member Join Date: Oct 2007
Member: 610864 Status: Offline Thanks Meter: 2 | i think you may find a repair guide just because of ic2 is damage....try this link bro. install the nokia hard library on your pc and find the solution there. http://www.4shared.com/file/17839710...ackAttack.html |
02-26-2008, 09:52 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | brother which keys r not working check this this will help u Upper ic = Connector Pin 1. Gnd 2. 3, 6, 9, # 3. 1, 4, 7, ABC 4. Call, 4, 5, 6 5. Clr, ABC,*, # 6. +v led 7. Right soft key 8. Menu, Left, Soft key 9. Joystick (Right) 10. Joystick (Left) Lower ic = Connector pin 11. Joystick (center) 12. Joystick (down) 13. Joystick (Up) 14. Left soft key, Right soft key 15. Gnd 16. 1,2,3,0 17. End call, 7, 8, 9 18. Menu 19. 2, 5, 8,* 20. Call, End call, Clr, 0 ic connect in1(i1) to out1(o1) 5 4 3 2 1 i7 gd gd i3 x A i9 gd gd i5 i1 B i10 i8 i6 i4 i2 C o9 o7 o5 o3 o1 D o10 o8 o6 o4 o2 E you can short I1 -->O1 I2-->O2 I3-->O3 I1 from cpu and O1 is connected to key board connect post results |
K610i sim jacket print damage pplz give print way urgent | asif_ae | Sony Ericsson Hardware Repair | 1 | 02-28-2011 11:10 |
nokia 6600 one key pad ic print damage need help | Hitesh manocha | Nokia Hardware & Hardware Repair | 0 | 10-14-2009 12:06 |
1200 keypad print damage | ameho0102 | Nokia Hardware & Hardware Repair | 9 | 06-01-2009 11:17 |
6600 on off print damage | ameho0102 | Nokia Hardware & Hardware Repair | 0 | 11-29-2008 11:54 |
7610 keypad print damage | ameho0102 | Nokia Hardware & Hardware Repair | 2 | 10-05-2008 05:11 |
