Old 11-28-2008, 08:54   #1 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
6600 need help
n6600 white screen and then turns off, i had flashed it many times but can not make ui settings .....i had also changed 3 boot ic but sill white screen..... any one please help me its very urgent....
Old 11-28-2008, 09:37   #2 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
please help me.......i need urgent help ..
Old 11-28-2008, 09:43   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
as of now still white screen
1. try replace new lcd
2. format fone after format unlock
Old 11-28-2008, 09:58   #4 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
bro lcd is ok and nokia logo is not coming ........set hangs on white screen and after some time turns off...........
Old 11-28-2008, 10:53   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
friend reflow or reball flash ic , post result
Old 11-28-2008, 10:57   #6 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
due to no local mode after flash
try rehot black ic near battery terminal
Old 11-28-2008, 12:04   #7 (permalink)
tiju kkm's Avatar
Member: 699986
Sonork: TIJU
Thanks Meter: 394
Problem not solved flash the phone with latest vertion
The Following User Says Thank You to tiju kkm For This Useful Post:
Old 11-28-2008, 12:57   #8 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
Bro its boot ic and i had changed 3 boot ic but problem not solve
Old 11-28-2008, 13:02   #9 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
any other solution please
Old 11-29-2008, 06:46   #10 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
please help me i had changed 3 boot ic and also flashed it many times
Old 11-29-2008, 06:55   #11 (permalink)
my_foo's Avatar
Member: 288291
Thanks Meter: 26
check ur blue tooth device if problem not solve then check ur uem
Old 11-29-2008, 06:58   #12 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
reball uem & flasher then post result
Old 11-29-2008, 07:07   #13 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
make smps jumper cheak and post
Old 11-29-2008, 08:05   #14 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
which smps jumper can u please load the image
Audiovox 6600 - need help ag70 Various CDMA/TDMA Cell Phones 0 10-22-2006 10:38
6600 need help shawgsm Nokia Hardware & Hardware Repair 2 01-31-2006 16:25
6600 need help please.... mgcomp Nokia Hardware & Hardware Repair 1 05-29-2004 18:22
Page generated in 0.23603 seconds with 10 queries
