09-10-2007, 10:54 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | 6600 lcd light does not work sir today i receive one 6600 nokia the fault is lcd light does not work and keypad lights work well now i changed coil and ic (1851) but problem remain same then i changed all resistence and transistor near te coil and ic 1851. but problem not solve. please help me to solve this problem. |
The Following User Says Thank You to amardeepsahi For This Useful Post: |
09-10-2007, 15:52 | #3 (permalink) |
Member: 357914 Status: Offline Thanks Meter: 71 | yes sir i also change the lcd with new one and also check on other plate its work bot on 6600 fault plate it does not work |
09-10-2007, 16:35 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 49
Member: 101891 Status: Offline Thanks Meter: 277 | 6600 lcd led bro please try to check the voltage on this connector , is this ok or not? |
The Following 2 Users Say Thank You to navin71 For This Useful Post: |
03-08-2009, 10:36 | #7 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Pakistan Age: 58
Member: 223710 Status: Offline Thanks Meter: 246 | 6600 Dispplay light 6600 display light solution .............. by multi system |
The Following User Says Thank You to multisystem For This Useful Post: |
05-28-2009, 20:35 | #9 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 289307 Status: Offline Thanks Meter: 44 | http://forum.gsmhosting.com/vbb/show...ght=6600+light it works 100% |
N70 keypad and lcd lights does not work.. need help pls. | bakhshalvi007 | Nokia Hardware & Hardware Repair | 4 | 08-08-2008 07:35 |
N73 LCD and Keypad Lights does not work.. need help please | bakhshalvi007 | Nokia Hardware & Hardware Repair | 3 | 03-13-2008 11:45 |
1110 rh 70 Lcd lights r not working | khurram786 | Nokia Hardware & Hardware Repair | 1 | 05-08-2007 08:42 |
A50 lcd lights are not working | walli Turab | Siemens Hardware Repair Area | 2 | 03-10-2007 11:48 |
w3000 LCD backlight does not work | $ide$tep | LG | 0 | 04-15-2005 08:32 |
