6600 phone start up failed contect the retailer :)hi everybody, i face the problem in 6600 phone start up failed. ... i try to manual format whith *-call button-3 and power on but format proccess not complite, i also try to manual erasing process whith jaf and ufs both but last area can not erase and error comming. i strickly resold cpu and s-ram also but not success still phone has same condition. please if any body has perfect solution share whith me. i confused:rolleyes: thanks in advance... |
first serch this forum befor post |
flash using jaf then write good pm then go to format then it will be ok |
hy . press * # 3 on off key togohter priess , |
try to hard format press*,3 ,green button and on/off button together |
try to ufs formate ithink ur problem solved |
plz flah phone n also check f11 n also check upp |
try last solution is change uem |
what is uem? can you show the schematic or picture? do i have to flash it again after putting new uem? thanks. |
this is a normal software problem. is solved by ufs , just make full factory then press normal mode, after normal mode is activated (sometime it is may be failed , no wooried), then press test mode, then press formate user area, and last make normal mode again. probem will be solved easily. post the result . DON'T TOUCH THE UEM. |
If Problem Is Not Solved With Formetiting Then You Should Reball Right Hand Side Flash Ic Problem Will Be Solved Just Do It Carefully. Good Luck. |
just do userarea formate 99% ur problem will be solve.... with jaf or ufs and do ui settings ..... |
Its Software Prob Just Flash The Set With Lastest Version Ur Set Will 101%%%%%%%%%%%%%% Ok |
re: Quote:
