Old 03-31-2008, 06:08   #1 (permalink)
Member: 321534
Thanks Meter: 18
6600 phone start up failed contect the retailer
hi everybody,
i face the problem in 6600 phone start up failed. ... i try to manual format whith *-call button-3 and power on but format proccess not complite, i also try to manual erasing process whith jaf and ufs both but last area can not erase and error comming. i strickly resold cpu and s-ram also but not success still phone has same condition.
please if any body has perfect solution share whith me. i confused
thanks in advance...
Old 03-31-2008, 06:12   #2 (permalink)
cooldreams's Avatar
Member: 171336
Thanks Meter: 53
Cool
first serch this forum befor post
Old 03-31-2008, 06:21   #3 (permalink)
Member: 511488
Thanks Meter: 8
flash using jaf then write good pm then go to format then it will be ok
Old 03-31-2008, 06:31   #4 (permalink)
aleem26's Avatar
Member: 241661
Thanks Meter: 255
hy . press * # 3 on off key togohter priess ,
Old 03-31-2008, 06:34   #5 (permalink)
bhogpurmail's Avatar
Member: 189506
Sonork: 100.1576871
Thanks Meter: 121
try to hard format press*,3 ,green button and on/off button together
Old 03-31-2008, 07:05   #6 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 200
try to ufs formate ithink ur problem solved
Old 03-31-2008, 07:46   #7 (permalink)
ranji's Avatar
Member: 670594
Thanks Meter: 51
plz flah phone n also check f11 n also check upp
Old 03-31-2008, 07:47   #8 (permalink)
ranji's Avatar
Member: 670594
Thanks Meter: 51
try last solution is change uem
Old 03-31-2008, 08:09   #9 (permalink)
Member: 96630
what is uem? can you show the schematic or picture? do i have to flash it again after putting new uem? thanks.
Old 03-31-2008, 08:20   #10 (permalink)
Member: 244357
Thanks Meter: 70
are you crazy ?
this is a normal software problem.
is solved by ufs , just make full factory then press normal mode, after normal mode is activated (sometime it is may be failed , no wooried), then press test mode, then press formate user area, and last make normal mode again.
probem will be solved easily.
post the result .
DON'T TOUCH THE UEM.
Old 03-31-2008, 13:22   #11 (permalink)
Member: 572872
Thanks Meter: 21
If Problem Is Not Solved With Formetiting Then You Should Reball Right Hand Side Flash Ic Problem Will Be Solved Just Do It Carefully. Good Luck.
Old 03-31-2008, 16:18   #12 (permalink)
Member: 471232
Thanks Meter: 17
just do userarea formate 99% ur problem will be solve.... with jaf or ufs and do ui settings .....
Old 03-31-2008, 16:33   #13 (permalink)
MEDIA_NADIM's Avatar
Member: 268712
Thanks Meter: 479
jst do user area format with ( * green 3 ) it ph didnt on dan u hv 2 replace booting ic dan it ll be oky
Old 03-31-2008, 16:44   #14 (permalink)
rose4u86's Avatar
Member: 500858
Sonork: 1589054
Thanks Meter: 392
Its Software Prob Just Flash The Set With Lastest Version Ur Set Will 101%%%%%%%%%%%%%% Ok
Old 03-31-2008, 17:53   #15 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 146
re:
" plz read the post before firing the replies becz urs replies is the post by him"
N95 8gb phone atart up failed contect the retailer sajidashraf Universalbox 23 02-10-2010 13:21
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) dmaetrey MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-08-2010 13:46
pls help me..!!6630 after flash phone start-up failer.contect the retailer ahsam Nokia Hardware & Hardware Repair 12 05-26-2007 12:14
Page generated in 0.40000 seconds with 8 queries
