Old 05-13-2006, 08:28   #1 (permalink)
Member: 9491
Thanks Meter: 14
6600 power on problem
i can full flash the set i.e. nokia 6600 but the set dose not power on.
Old 05-13-2006, 08:50   #2 (permalink)
Member: 121368
Thanks Meter: 3
reflash other firmware bit before you do that erase manualy and proceed to normal flashing
Old 05-13-2006, 09:48   #3 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
i
thanks for gsm its good slotion
wajid gsm
Old 08-10-2006, 09:37   #4 (permalink)
Member: 12724
Thanks Meter: 30
I have same problem.It is hardware problem.I am working and if I found what is it,i will post results
Old 08-10-2006, 09:55   #5 (permalink)
Member: 153278
Thanks Meter: 2
which flasher use..???
pls explain...
Old 08-12-2006, 09:26   #6 (permalink)
Member: 9491
Thanks Meter: 14
Ufs,griffin, Univeral
7610 power on problem no power on with power touch shani72 Nokia Hardware & Hardware Repair 2 09-10-2008 05:51
6600 Power On And Jammed chip_2000 Nokia Hardware & Hardware Repair 18 08-10-2006 09:40
6600 powering on by itself when battrey is inserted.... switch has no effect at all Burnt Cobba Nokia Hardware & Hardware Repair 4 04-11-2005 19:51
6600 Power On/Off Rahuman28 WD2 & APE (Symbian Phones) 1 04-01-2005 18:56
6600 Power On/Off Rahuman28 Griffin 2 03-21-2005 10:49
Page generated in 0.50285 seconds with 10 queries
