Old 02-05-2006, 16:49   #1 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
6600 Problem
Hi
We Got 1 6600 on open gallery problem.
after resold its bluetooth ic..set is dead now...
BUT
when i attach the phone with ufs or griffin ..phone is on..and its power button is oki...but set cant be on with battery
and phone cant accept flash with any software..griffin .mt .jaf.ufs etc.
phone is DEAD now
WBR
Kuku
Old 02-05-2006, 18:46   #2 (permalink)
Member: 58665
change the bluetooth IC
Old 02-05-2006, 20:33   #3 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
now set is on..but off after 30 seconds..
we on the phone with hardware..
what is the solution now ?
WBR
Kuku
Old 02-06-2006, 13:15   #4 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
@.:KuKu:.
just check imei if no problem in that then just see urs crystel ic called ram below cpu
Old 02-06-2006, 16:40   #5 (permalink)
amps_jas's Avatar
Member: 218135
Thanks Meter: 7
.:Kuku:.
when you rehot the bluetooth module did you noticed that the uem is on the other side of the board? your problem might be loosed or cold soldered parts on the side of the uem, or worst the uem is now cold soldered because of the extensive heat you created while resoldering the bluetooth module.
try to rehot all the parts on the side of uem.
Old 02-09-2006, 03:35   #6 (permalink)
Member: 149576
Thanks Meter: 57
yes maybe u damaged the uem already.
Old 02-09-2006, 05:03   #7 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
6600 bt
ita a normal fact many people come to me who make there sets go dead while changing bt module in that case u need to take off the glued uem and reball or replace (its a real pain in the *** as this takes a lot of your time)
6600 problem with Oxygen phone manager! pedjulino Nokia Multimedia 6 05-06-2004 20:57
Nokia 6600 problem Unlocker AL Griffin 2 05-06-2004 18:19
6600 problem gsm-decode Twisterflasher 2 05-04-2004 09:19
PC suite for Nokia 6600 problem,Heeeelpe me tareg2001 WD2 & APE (Symbian Phones) 0 03-21-2004 17:49
6600 problem... reminds me of 3650 fading :( Burnt Cobba WD2 & APE (Symbian Phones) 2 12-16-2003 16:07
Page generated in 0.16833 seconds with 9 queries
