03-15-2005, 09:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Poland/Germany Age: 42
Member: 87533 Status: Offline Thanks Meter: 3 | 6600 restarts (white screen after change UEM) I have changed UEM in 6600 and now after power on - only white screen and shutdown after 2 seconds. Flashing is ok. What to do? |
03-15-2005, 10:03 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Try to Heat little bit more on UEM. If not remains power on It means UEM is faulty, To check wether UEM is good, Power on the phone it should not switch off within 45 Seconds it should remain on. If phone switches off then UEM is Faulty. |
03-15-2005, 10:23 | #4 (permalink) |
Member: 87533 Status: Offline Thanks Meter: 3 | I have already probramed the UEM with the RPL file, but after the checksum there was a error that the phone connot go into Local Mode (on Twister) .... so is there any possibility that the phone shut down, becaus there is a other imei in flash as in the UEM? But on "check" it shows that imei whit them I have programed the UEM |
03-15-2005, 11:24 | #5 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | If u have replaced the UEM doubt go to UEM, Have u tried to erase full flash Then write Mcu Ppm and if it dose not solve thye problem try to flash only ppm. what dose it says tell me. But first Erase full flash and write it. |
03-16-2005, 17:26 | #7 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Tell every one here How did the Problem solved. This forum is for all so that we can help each other. This forum as a community of mobile repairing Family. Ok ! |
03-17-2005, 10:48 | #8 (permalink) |
Member: 87533 Status: Offline Thanks Meter: 3 | Repaired with Twister Flasher: 1. Erase the flash from adress 0000000 to 07FFFFF (or use erase files on griffin) 2. Flash it with latest software 3. Write PM for 6600 4. Make Format User Area 5. Make Reset Full Factory Defaults 6. Unlock phone That was that I have done .... |
help with n70 white screen after changing bleutooth ic | gsmspace | Nokia Hardware & Hardware Repair | 5 | 06-25-2008 04:35 |
help for N70 white screen after change sim ic | chronic | Nokia Hardware & Hardware Repair | 1 | 01-22-2008 20:40 |
6060 white screen after change SIM! | dem3ntor | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 06-18-2007 11:47 |
U8110 white screen after changing connector | wizz25 | LG | 1 | 09-15-2006 18:58 |
white screen after changing 7610 upp v3.2e | genocite | Nokia Hardware & Hardware Repair | 4 | 03-21-2005 22:41 |
