10-11-2007, 11:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Dombivli (E) Age: 48
Member: 124938 Status: Offline Thanks Meter: 69 | 6600 Short.. Nokia 6600 shorting when checked at the battery point. It is not fully shorted but both sides are low. I cleaned with Elma but still no progress. I examined the board and removed the following components for checking: 1) Zocus 2) SMPS 3) PA 4) Antenna Switch (Rusted) Still both sides low. The shield of BT chip was removed and IC's looks suspicious. Can this may be the reason of shorting?? Please guide me. Thanks Aju |
The Following User Says Thank You to ajubaba For This Useful Post: |
10-11-2007, 20:23 | #2 (permalink) | |
Insane Poster Join Date: Feb 2007 Location: Abu Dhabi,UAE
Member: 447572 Status: Offline Thanks Meter: 5 | Quote:
Does it drain d battery easily thou it's working? | |
10-12-2007, 07:42 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: INDIA
Member: 463150 Status: Offline Thanks Meter: 91 | u can check the crystal i.c and coil- maximum time short are being from these component. try these may be ur problem solved |
The Following User Says Thank You to vishal123123 For This Useful Post: |
6600 short remove | ratan_deb | Nokia Hardware & Hardware Repair | 1 | 12-23-2009 10:57 |
6600 Shorted Battery terminal | Sgt.Maganto | Nokia Hardware & Hardware Repair | 1 | 05-16-2008 19:48 |
6600 mmc short | vikas kumar | Nokia Hardware & Hardware Repair | 0 | 12-03-2007 08:15 |
Nokia 6600 full short | zakir375 | Nokia Hardware & Hardware Repair | 3 | 04-23-2007 13:38 |
Nokia 6600 dead after removing short BT | zakir375 | Nokia Hardware & Hardware Repair | 1 | 12-12-2006 06:33 |
