10-04-2006, 23:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | 6600 strange problem |
10-06-2006, 04:03 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | bt problem Quote:
have u tried to flash it after u change ur bt module.......... if not!!!!!!!!!? flash it and write pm!!!!!!!!!! post result>>>>>>>>>>>> luck dude! | |
10-06-2006, 08:52 | #6 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | yeah its more serios...you can rehot it simply and nice and mild...put a flux to the bt module.,,,and put also a flux at the back...because uem and some major parts are at the back.,,,,.... |
10-09-2006, 03:52 | #11 (permalink) | |
in some cases yes!!!!!!!!!!!!! but i think problem came from the upp........... how many times u change your module!!!!!!!! i suggest that u should try to replace again the module, it happen to me often, i change the module trice,,,,,,,,,,,,,,,,,,,,,, and if doesnt fix that way then.. try to reheat upp!!!!!!!!!!!!!! luck dude!!! post result... wbr | |
03-08-2008, 16:03 | #13 (permalink) | |
Freak Poster Join Date: Feb 2004
Member: 55247 Status: Offline Thanks Meter: 4 | Quote:
same problem here..i just change bluetoth ic then no network...pls help | |
nokia 6600 strange problem | obioha | powerflasher | 6 | 06-11-2007 10:40 |
6600 strange problem | El VaQuito | WD2 & APE (Symbian Phones) | 7 | 06-21-2005 18:36 |
6600 strange problem (need help urgent!!!) | alex yong | WD2 & APE (Symbian Phones) | 2 | 02-02-2005 15:38 |
6600 strange problem | Byte | Nokia Hardware & Hardware Repair | 0 | 12-13-2004 17:24 |
