Old 12-15-2007, 16:08   #1 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
6600 UEM Problem..Pls Check it..
hi all..
phone was working fine..i changed the uem ic.. i tried to write rpl file by ask rpl service.. but rpl file not written. i think uem was damaged...and after that i flashed it wit latest fw.. 5.53..after flashing phone is dead.. only white screen (no shown nokia) after 20-25 sec later phone is power off.. then i tried 5-6 used uem..but still same...
can sb give me an advice..? old uem is no wroking..
Old 12-15-2007, 16:14   #2 (permalink)
Boyofkashmir's Avatar
Member: 642074
Thanks Meter: 1,955
Check
Problem should b on flash ic's if ui seting not done after flash
Old 12-15-2007, 16:16   #3 (permalink)
Member: 642074
Thanks Meter: 1,955
Check
Prob should be on flash ic's if ui setting not done
Old 12-15-2007, 16:22   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
thanx mate..
but phone was working after changing uem..after flashing no power on again.. only white screen and goes off.. and ui settings not done cause of no power on.. no local or test mode..
Old 12-15-2007, 18:49   #5 (permalink)
Member: 465901
Thanks Meter: 45
problem definatily lies in the flash ic's
Good Luck
Old 12-15-2007, 19:31   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Good Luck
thanx mate...
but phone was working fine after changing uem.. after flashing no power on.. i think pb is not flash ics.. if i can find working uem + flash ics i will change them.. but i need solution urgently..
Old 12-15-2007, 22:30   #7 (permalink)
Member: 390359
Thanks Meter: 30
you still have a problem with uem. what is the number on uem that you used? ....825 or ....001 number uem is working on 6600.
if you have same number 3100 uem (no glued) use on 6600.. full flashing and look at screen. if nokia shows its okk. then we continue with 3100 uem
Old 12-16-2007, 09:10   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
thanx...
4370825 uems not booting with ufs.. it means ufs not detect the upp and uem.. not compatible with my 6600 4370825 uems.. but when i have solder another uem f.e. 4370959, booting..and flashing successfull but no power on.. only white screen....
Old 12-16-2007, 15:20   #9 (permalink)
Member: 390359
Thanks Meter: 30
Originally Posted by just_learn View Post
thanx...
ook just try no glued uem that number ...001 ...025.. 6610-3100 etc uem.
Old 12-16-2007, 21:02   #10 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi, I think problem is uem, but try ppm flash only first. if not done then reball uem......
Old 12-16-2007, 21:35   #11 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
thanx mates.. i wil check again.. but i think pb wont be solved..
Old 12-17-2007, 10:43   #12 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi all again...
4370959 uem number is compatible with 6600..? i have a workig fine on the 3200 phone..
4370825 uems not detecting by ufs..
Old 12-17-2007, 11:17   #13 (permalink)
Member: 390359
Thanks Meter: 30
hi all again...
i had same problem a few days ago. after changing uem then flashing becomes white screen freezing... if u dont look anywhere except uem. your problem is with program and uem.
first full program with latese versiyon mcu and ppm. do not do ui set
then read uem imei with jaf. make ask and take rpl with log.
write rpl.
ui settings
format user area. okk..
i used 4370825 uem. but also tried with ...001 uem.
Old 12-17-2007, 12:26   #14 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
write rpl.
ui settings
and Bingo.. after ask rpl service phone is oki.. thanx mate.. and i wrote rpl file to used uem..
Old 12-17-2007, 12:30   #15 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
and uem number is .....001
rpl still not arrive pls check it shawgsm Gsmfather The Wholesale Unlocking Database 3 06-25-2009 09:39
Gsmkoolets forum pls check it out!!! rhex21 GSM Mobile Links 0 03-14-2009 13:23
Wrong RPL or my phone?pls check it! gjurobrod Gsmfather The Wholesale Unlocking Database 9 07-17-2008 13:33
Siemens Hardware Experts..Pls Check it..SL55 Simways.. LoveLess Siemens Hardware Repair Area 4 03-04-2007 16:18
Page generated in 0.29731 seconds with 9 queries
