Old 11-12-2007, 15:22   #1 (permalink)
deepaksawdia's Avatar
Member: 108186
Thanks Meter: 241
6600 very common but not solved problem
brother i face this problem many time in nokia 6600 7610 3230. 1st boot ok erasing and flashing 100% done. but ui setting and formet user aria failed .and set remain dead. expert plese help me which ic or component faulty
Old 11-12-2007, 16:09   #2 (permalink)
Member: 465901
Thanks Meter: 45
reball flash ics i had solved this problem in many 6600 phone, this is the fault of flash ics
Old 11-12-2007, 17:13   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,338
reball or change d316 post result
Old 11-12-2007, 18:15   #4 (permalink)
Member: 227127
Thanks Meter: 239
in some cases ZOCUS IC cause this fault.
Old 11-13-2007, 06:46   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,693
BRTHR CHANGE BOOT IC .....................BECAUSE IT MAIN REASON OF THIS FAULT........ THEN AFTER FLASH IT.......
Old 11-13-2007, 07:32   #6 (permalink)
Member: 446221
Thanks Meter: 23
yes, change booting ic(sensing) ur problem will solve
Old 11-13-2007, 07:41   #7 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 267
about 6600 how to can solved prob
hello every body,
6600or 7610 or 3230 common prob I also faice so many time and finaly I get solution .....can possibal to done softwear maximum case no nee Hw...select mcu and ppm and flash it mcu ppm flash compelete then check lcd there show nokia logo if not show then change ppm file better china ppm file must be show nokia logo but one think flash only ppm . i get result so many times .......one think again if your set have blutooth problem and you wanto flash it may set will be dead . that time you have seen the first boot ok but did not take flash ...read very clearly that time you have need to diseable bt flashing you flashing windows ...apply your self you must be get result........good luck some case offcoruses have hardwear porb....
Old 11-13-2007, 09:29   #8 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 267
hi…((((((..I have a tactic mcu file is euro and ppm file is china flash ok then change ppm file I get allows successful))))))….. good luck
Old 11-19-2007, 13:27   #9 (permalink)
ikhlaq's Avatar
Member: 147811
Thanks Meter: 27
6600 White Lcd/ No Boot Slution
Originally Posted by sopnil View Post
hello every body,
HI ALL .
IN MANY MANY CASES THERE IS HARDWARE PROBLEM.
DO THIS AS PICTURE
File Type: jpg nokia-6600-lightonly-slution-by--IKHLAQ.JPG (98.4 KB, 357 views)
Old 12-02-2007, 19:55   #10 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 95
hello every body,
100% software no need hafdware flase with higher version
Old 12-05-2007, 16:50   #11 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
yes its 100% softwere not hard were erase manual and flash it new ver .
first of all
this problem happend after wrong flash
or u recive the phone with this problem and normal flashing with mcu and ppm not help to repair this problem
so do next
1- with ufs box start to erase manual this adress
start: 00000000 end: 00FFFFFF
start: 02000000 end: 02FFFFFF
start: 04000000 end: 047FFFFF
this 3 adress will eras the 3 flash's and u will not lost ur phone imei
2- with ufs again erase
start: 00010000 end: 0000FFFF
start: 02000000 end: 00FFFFFF
start: 02FC0000 end: 0286FFFF
start: 02A00000 end: 0000FFFF
3- flash ur phone with latest firmware
4- write full pm to ur phone
5- unlock and format user area
if ur blank phone (7610-6670-3230 ) the problem up to software by this solution will work 100%
Old 12-05-2007, 19:09   #12 (permalink)
mustafa_180's Avatar
Member: 638097
Sonork: 100.1649741
Thanks Meter: 43
Thank you Every one ,Very very much
From Masum.
The Following User Says Thank You to mustafa_180 For This Useful Post:
Se W810i Charge Not Solved Problem? ..::khaled::.. Sony Ericsson Hardware Repair 1 11-02-2009 10:12
6600 showing charing but not get chargig pawan_verma51 Nokia Hardware & Hardware Repair 1 12-25-2007 09:21
some 6600 ""INSERT MMC""problem can not solve.is it due to upp? zonetrichur Nokia Hardware & Hardware Repair 0 10-23-2007 18:52
help me 6600 flash ok but not power on kirpiksk Nokia Hardware & Hardware Repair 2 08-09-2006 07:12
6600 Flash ok but not running tuhingr UFS2 + UFS3-Tornadoflasher 2 12-21-2005 09:56
Page generated in 0.40447 seconds with 9 queries
