11-12-2007, 15:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: raigarh india Age: 51
Member: 108186 Status: Offline Thanks Meter: 241 | 6600 very common but not solved problem |
11-13-2007, 07:41 | #7 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | about 6600 how to can solved prob hello every body, 6600or 7610 or 3230 common prob I also faice so many time and finaly I get solution .....can possibal to done softwear maximum case no nee Hw...select mcu and ppm and flash it mcu ppm flash compelete then check lcd there show nokia logo if not show then change ppm file better china ppm file must be show nokia logo but one think flash only ppm . i get result so many times .......one think again if your set have blutooth problem and you wanto flash it may set will be dead . that time you have seen the first boot ok but did not take flash ...read very clearly that time you have need to diseable bt flashing you flashing windows ...apply your self you must be get result........good luck some case offcoruses have hardwear porb.... |
11-19-2007, 13:27 | #9 (permalink) | |
Freak Poster Join Date: May 2005
Member: 147811 Status: Offline Thanks Meter: 27 | 6600 White Lcd/ No Boot Slution Quote:
IN MANY MANY CASES THERE IS HARDWARE PROBLEM. DO THIS AS PICTURE | |
12-02-2007, 19:55 | #10 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Mumbai Age: 43
Member: 523792 Status: Offline Thanks Meter: 96 | Quote:
12-05-2007, 16:50 | #11 (permalink) |
No Life Poster Join Date: Sep 2005 Location: PAKISTAN Age: 39
Member: 181886 Status: Offline Sonork: 100.1579817 Thanks Meter: 1,007 | yes its 100% softwere not hard were erase manual and flash it new ver . first of all this problem happend after wrong flash or u recive the phone with this problem and normal flashing with mcu and ppm not help to repair this problem so do next 1- with ufs box start to erase manual this adress start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF this 3 adress will eras the 3 flash's and u will not lost ur phone imei 2- with ufs again erase start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 3- flash ur phone with latest firmware 4- write full pm to ur phone 5- unlock and format user area if ur blank phone (7610-6670-3230 ) the problem up to software by this solution will work 100% |
Se W810i Charge Not Solved Problem? | ..::khaled::.. | Sony Ericsson Hardware Repair | 1 | 11-02-2009 10:12 |
6600 showing charing but not get chargig | pawan_verma51 | Nokia Hardware & Hardware Repair | 1 | 12-25-2007 09:21 |
some 6600 ""INSERT MMC""problem can not solve.is it due to upp? | zonetrichur | Nokia Hardware & Hardware Repair | 0 | 10-23-2007 17:52 |
help me 6600 flash ok but not power on | kirpiksk | Nokia Hardware & Hardware Repair | 2 | 08-09-2006 06:12 |
6600 Flash ok but not running | tuhingr | UFS2 + UFS3-Tornadoflasher | 2 | 12-21-2005 09:56 |
