Old 01-19-2007, 05:57   #1 (permalink)
Member: 428839
Thumbs down 6600 White Display
i have 6600 in UFS SET LOCAL MODE OK also NORMAL MODE OK ,in battery set is white disply ANY SOLUTION
Old 01-19-2007, 06:03   #2 (permalink)
Member: 432364
Thanks Meter: 270
in ufs normal mode your handset is working then ok if it is blank change display.
Old 01-19-2007, 08:58   #3 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Replace the IC near at boot IC beside battery connector....
Old 01-19-2007, 14:19   #4 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
What you mean psunil??????????????
Old 01-20-2007, 03:46   #5 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
yes capri is right... replace crystal ic near bsi..
wbr
nokia 6600 white display after water clean MisticRaider Nokia Hardware & Hardware Repair 11 07-04-2008 00:02
6600 white display paklink UFS2 + UFS3-Tornadoflasher 13 08-06-2006 22:47
6600 white display tajinder Nokia Hardware & Hardware Repair 5 05-23-2006 01:20
6600 white display BIJESH Nokia Hardware & Hardware Repair 3 01-29-2006 18:39
6600 white display paklink Nokia Hardware & Hardware Repair 6 09-29-2005 13:59
Page generated in 0.17693 seconds with 10 queries
