08-23-2008, 12:16 | #2 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Quote:
1. Check ur display --- replace or change with another display 2. Check ur display conector --- replace or change ur display conector 3. Check all track on ur from display conector to display IC -- if cut please jumper 4. Check ur display IC -- reball or change 5. Before change ur display IC please check all pin track on ur board. 6. If same -- reheat verry carrefully ur UPP, reball UPP or change UPP goog luck | |
The Following User Says Thank You to AdickAsia For This Useful Post: |
08-23-2008, 12:49 | #3 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | first of all post always complete history of ur handset it is helpfull for every members. and do as like adickasia says. but if u can not make or recive calls then connect with ufs and check local mode, and if local mode does not ok and u can not take info then it is the problem of boot ic near battry connector. try to change it, and post result if not solve then tell here ok i am waiting ur answer |
nokia 6600 white display after water clean | MisticRaider | Nokia Hardware & Hardware Repair | 11 | 07-04-2008 00:02 |
6600 white display | paklink | UFS2 + UFS3-Tornadoflasher | 13 | 08-06-2006 22:47 |
6600 white display | tajinder | Nokia Hardware & Hardware Repair | 5 | 05-23-2006 01:20 |
6600 white display | BIJESH | Nokia Hardware & Hardware Repair | 3 | 01-29-2006 18:39 |
6600 white display | paklink | Nokia Hardware & Hardware Repair | 6 | 09-29-2005 13:59 |
