Old 08-25-2004, 18:46   #1 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
6600 white lcd...
I got this day a nokia 6600 with white lcd,
i erase it "full erase" using griffin, and flash it but the same , i try to read imei data using griffin i got ????????????????? , now the phone is only power with white screen ..., does it need RPL file ...? or what ...?
Old 08-25-2004, 19:29   #2 (permalink)
eeprom_flash's Avatar
Member: 58599
Thanks Meter: 2
reflash fone properly it would work, all u need is reflashing.........
Old 08-26-2004, 11:14   #3 (permalink)
Member: 7062
Thanks Meter: 126
mmm
i think you have problem with the uem ...
try flash it first with possible flashers
and see i recommend to try
1st prodigy
2nd griffin
3rd ufs3
wait to post the result ..
Old 08-26-2004, 17:57   #4 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
i only have griffin ...!!!
Old 08-28-2004, 15:12   #5 (permalink)
Member: 51453
Thanks Meter: 729
try to flash with chinese flashfile if it will display with chinese, then flash it with mcu & ppm.but if the screen still white rebuild your imei... hope this could help
Old 10-05-2004, 19:52   #6 (permalink)
Member: 80085
Thanks Meter: 5
your uem is death when imei is ???????????????? 100%
Old 10-09-2004, 20:48   #7 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
yes, i'm agree with you.
For all members, in DCT-4 with all flasher box (Griffin, Prodigy, UFS-3,etc) if the IMEI show ???????????? it means UEM faults, so it must be reflow or change. But after change the UEM we usualy get PHONE RESTRICTED shown on LCD, the next step after PHONE RESTRICTED shown we must reflash it with good flash file. in some flasher box we can't rebuild IMEI.
Best Regards
Old 11-04-2004, 09:48   #8 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
you was wrong step to repaire!, do not erase first but make full flash first, if still white change LCD, erase flash make make your imei ?????????????, if imei like this you need to rebuild imei so you need rpl file or change uem and rebuild imei, make .ask file and send to somebody how can convert it to .rpl file,
regart
Old 05-17-2005, 13:25   #9 (permalink)
FITOS's Avatar
Member: 111248
hey guys ....
in this case because i have excactly the same problem.......U have to format user area but in this problem is impossible to do it...SO....if u really know smth then reply.
Bless U
Old 05-18-2005, 15:11   #10 (permalink)
GSMARMOON's Avatar
Member: 90804
Thanks Meter: 46
6600?
full flash WITH UFS-3 100% tested and 100% working....
Old 05-18-2005, 15:33   #11 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
rebuild imei,try to fullflash,format and unlock,if it is fail then change uem.post the result or screeenshot so that we can help you.
Old 05-18-2005, 15:38   #12 (permalink)
Member: 94090
Thanks Meter: 26
I think that u say about fixing the white screen not serial ???????????,because it's uem problem.
6600 White Lcd W4r10rD Nokia Hardware & Hardware Repair 23 01-25-2008 09:19
help me 6600 white lcd _what can i do ahlawy6137 WD2 & APE (Symbian Phones) 2 12-08-2006 05:24
7610,6600 White Lcd FasGsm Nokia Hardware & Hardware Repair 1 08-17-2006 09:23
6600 white lcd The Repair Shop Nokia Hardware & Hardware Repair 23 02-15-2006 20:11
6600 White Lcd FITOS WD2 & APE (Symbian Phones) 5 02-28-2005 08:11
Page generated in 0.19822 seconds with 9 queries
