07-15-2006, 11:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | 6600 White Lights Only |
07-15-2006, 18:33 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | if white lights only then you can make a call rehot/change emif IC near LCD connector, but if it can not make a call try to rehot/reball ZOCUS (N301) Regards |
07-17-2006, 14:52 | #4 (permalink) |
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | I Found That This Problem Comes In 6600 With Most Of Bluetooth And Galary Problem And In Phone In Which We Hited The Module. What Happens To This Phone After Reball Or Hit. Problems Of White Lights Stell Continue Evenafter Removing Bt Module. |
07-17-2006, 14:59 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | Bro It Is Not Because Of Bt Module Ur Going In Wrong Direction Ur Phone Is Not Goin In Boot Mode That Why It Is So |
07-18-2006, 18:22 | #8 (permalink) |
Junior Member Join Date: Sep 2005 Location: Egypt Age: 46
Member: 183971 Status: Offline Thanks Meter: 0 | listen eraes 4 flash one by one then flash the phone with mcu +ppm +pm and if dosnt work rehot flash ic no 2 but be sure if the flash ic can c f10 f11 f12 f13 with the right adrees and right name |
6600 white light & keypad light blink 9 times | shoeb7 | Nokia Hardware & Hardware Repair | 5 | 06-13-2008 15:30 |
nokia 6600 WHITE LIGHT. INCOMMING AND OUTGOING CALLS ARE OK. | shahi | Nokia Hardware & Hardware Repair | 3 | 12-17-2007 07:30 |
strange problem in 6600 white light.... | digitized | Nokia Hardware & Hardware Repair | 7 | 10-01-2007 10:07 |
6600 white screen only | beega | Nokia Hardware & Hardware Repair | 13 | 07-16-2007 07:50 |
pls any one one guide me in 6600 white light | digitized | Nokia Hardware & Hardware Repair | 5 | 06-03-2007 03:50 |
