08-14-2007, 17:11 | #1 (permalink) |
Major Poster Join Date: Jul 2006
Member: 311456 Status: Offline Thanks Meter: 0 | 6600 white screen problem now i have an 6600 that is not effected with liquid or any other think and also never opened before. for a need i have to change the uem. i have desolve the uem from the board very clearly and the pins of the uem at the board is ok and clean. then i have put the new and the working uem to the board. when i pressed the on off switch the phone is opening and gets white screen no nokia image appears and not closing from the on off switch. does any one have an idea about this failure. the phone is with me more than 4 days. it is a very urgent topic for me. i have those boxes and the failures that i have taken is below universal box jaf (chk error) ufs3 (platfor 6 error) griffin (slow pc error) |
08-15-2007, 11:58 | #5 (permalink) |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | 1st check the zokus ic u must make sure the zokus ic is good,then use file Full Erase,after full erase try 2 upgrade with new version if show NOKIA do write PM and write rpl file(because as u say u have 2 change the new UEM)!!! good look |
08-16-2007, 07:26 | #6 (permalink) | |
Registered User Join Date: Oct 2006
Member: 380662 Status: Offline Thanks Meter: 117 | 6600 Quote:
i have faced same problem with 6600 some days ago i flashed phone but when i power on d phone it hangs on white screen then someone told me to reball d processor i opend d processor and reballed it and it worked if u wish u can try regards but in my case i didnt saw nokia written on screen it was totally white | |
help nokia 6600 white screen problem | MR.MAMUN | Nokia Hardware & Hardware Repair | 14 | 06-30-2009 08:41 |
my 6600 white screen problem | gm39772 | Nokia Hardware & Hardware Repair | 7 | 10-26-2007 03:20 |
6600 white screen problem | toolsveera | Nokia Hardware & Hardware Repair | 3 | 10-06-2007 07:25 |
6600 white screen problem | toolsveera | Nokia Hardware & Hardware Repair | 2 | 09-21-2007 17:12 |
6600 white screen problem | Nooboras | Nokia Hardware & Hardware Repair | 1 | 05-22-2007 18:49 |
