02-23-2006, 17:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 50
Member: 6358 Status: Offline Thanks Meter: 10 | 6600 white screen and shutdown after 33s But it has another problem, 33s after keypad lights go on during startup (when Nokia flashes), display goes white and phone goes off. You think it's UEM problem? Same thing happens if I remove display filter IC, phone goes off after 33s. By the way, IMEI is ok and phone works fine, but only for ~30s Best regards |
The Following User Says Thank You to fontelense For This Useful Post: |
02-25-2006, 11:13 | #2 (permalink) |
Junior Member Join Date: Dec 2003 Location: namibia;windhoek Age: 45
Member: 46304 Status: Offline Thanks Meter: 2 | hey man try this full erase 6600 flash mcu+ppm+cnt128+unlock after flash and ui setting also try to format user area works 100% for me also try this on to manual format phone (send key+*+3+power on ) |
The Following 2 Users Say Thank You to cellspeed For This Useful Post: |
03-03-2006, 23:48 | #7 (permalink) |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | If your phone go off after 30s ,the reasn is UEM.But befor change it try to make a rpl of this uem and write it to that.If this could't solve your problem then you should change the UEM IC |
03-04-2006, 09:07 | #10 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | Quote:
is UEM problem.. based on experiene its the same problem with 2300,1100, and 6230. you can retain your imei after changing UEM but dont chane it first.. use JAF imei tool to save your imei and ask file then you can change it.. hope i did give you a bit of help my friend.. | |
03-04-2006, 09:33 | #11 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IN ISLAM HEART Age: 39
Member: 85387 Status: Offline Thanks Meter: 78 | so whats solution we are waiting i dont think it need to change uem maybe if you read full pm using ufs then convert it to rpl using pmtorpl then instale rpl to phone then try and post replay |
03-04-2006, 22:41 | #15 (permalink) | |
Member: 29870 Status: Offline Thanks Meter: 24 | Quote:
WBR. | |
w810..white screen and vobration after flash!!! | hicvb7 | Cruiser Suite | 13 | 04-11-2007 08:14 |
6600 white screen and erasing failed???? | sallu | Nokia Hardware & Hardware Repair | 3 | 02-13-2007 17:51 |
6600 white screen and switch off | ziko | WD2 & APE (Symbian Phones) | 1 | 04-18-2005 16:01 |
6600 white screen after tornado flash | ckkckk | WD2 & APE (Symbian Phones) | 1 | 03-25-2005 14:30 |
