07-25-2006, 15:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: kerala,india Age: 47
Member: 93214 Status: Offline Thanks Meter: 18 | 2300 power on only in ufs..urgent |
07-25-2006, 17:32 | #4 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: TURKEY Age: 41
Member: 249504 Status: Offline Thanks Meter: 2 | Quote:
07-25-2006, 21:19 | #7 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
1st earse its flash n then reflash with 7.30 file version then tell me result wbr muhammad ahmad | |
07-26-2006, 06:08 | #8 (permalink) | |
Member: 93214 Status: Offline Thanks Meter: 18 | Quote:
08-02-2006, 02:00 | #10 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Adelaide Australia Age: 39
Member: 96184 Status: Offline Thanks Meter: 6 | i recon your all wrong, when you first flashed the phone it is likly that there was an error which would have changed the power levels, if you can get local mode, flash the phone but cannot power up the phone with a battery then the UEM would be behind it but its not faulty. you need to perform an energy managment calibration in 12volts using phonenix. the battery voltage goes way out in this fault, you need to use a good phone to copy the EM values to phoenix then connect the stuffed phone and load the new EM values to the phone. this works very well with 6255, 6111, 8800 and also 2300, 1100 have this problem. changing PA may help. if you are unable to perform this opperation- (takes 30 seconds) then you may need to replace the UEM as well. |
08-03-2006, 13:26 | #11 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | some of tis prob i encounter i sovle it by changing the time crystal ic jus seat beside the uem grey in colr or brown in color wit some code ont it... and s/w can be solve by the way erase flash then full flash.. write pm and init sim use version not higher then 7.XX below is better happy tryin |
6260 powers on only with UFS | mr_loverman | HWK | 3 | 08-21-2008 18:30 |
6260 on only in ufs solution | eldhoseca | WD2 & APE (Symbian Phones) | 0 | 07-21-2006 12:59 |
nokia 6260 on only in ufs .....help me ......plz | eldhoseca | Nokia Hardware & Hardware Repair | 0 | 07-12-2006 10:38 |
6260 on only in ufs,...help me please..... | eldhoseca | WD2 & APE (Symbian Phones) | 0 | 07-12-2006 10:31 |
help!!! 6101 power on only with ufs | tiosif | Nokia Hardware & Hardware Repair | 1 | 03-10-2006 17:03 |
