06-01-2004, 12:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: BiH Age: 49
Member: 46341 Status: Offline Thanks Meter: 15 | 6610 dead but flash ok Area: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area: 0x01010000-0x0157FFFF Erased, Time: 00:46 Area: 0x016B0000-0x017EFFFF Erased, Time: 00:11 Area: 0x01EB0000-0x01FEFFFF Out of Chip Bounds I change uem stil dead. Phone cant go to eny mode-test etc. |
06-04-2004, 13:59 | #4 (permalink) |
Member: 46341 Status: Offline Thanks Meter: 15 | EHH power swich is ok ofcorse. But I tread erse holl flash and I olso get mesage -out of chip bounds. I put ram on 6210 board and 6210 power on whitouh problem, so ram is olso ok( I think). I put UEM from working 8310 unit- olso no power on. |
06-06-2004, 04:18 | #5 (permalink) | |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
flashing o.k mean its have all flash file written and the phone not extract cnt file sure and afp not done .. one case i agree with you may b he can check the power switch only if the phone enter local mode o.k and test mode and normal but not power up ... @kriza i think you problem in the flash ic it self bad one try to chnage the flash ic try to reflow the upp ... more pm me thx br. | |
06-06-2004, 17:01 | #6 (permalink) |
Member: 46341 Status: Offline Thanks Meter: 15 | I order flash chip, but I must long wait. But I wonder-how can be flash chip dameged if flashing ok.? Is there eny procedure to chek UPP (by mesuring voltage?) I hawe 2,4v on power swich. |
06-09-2004, 04:34 | #7 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | i have this problem now on a 3100 phone too. It's a water damaged case problem, and i already clean the phone, and the phone can be flash without single problems, BUT only won't write the PM files. and the phone won't turn on! what is happeing |
06-09-2004, 06:55 | #9 (permalink) | |
Freak Poster Join Date: May 2002 Location: B&H, Australia
Member: 11715 Status: Offline Thanks Meter: 5 | Quote:
I had -out of chip bound message with 7210, and fixed just with latest sw version. No needed touch hardware. | |
06-11-2004, 22:51 | #11 (permalink) |
Member: 11715 Status: Offline Thanks Meter: 5 | @KRIZA I didn't say i fixed it. I had phone which couldnt turn on. Friend was ************ed it with some older dct4 box. I tryed a couple times to flash it with different sw version and I had that message during flashing. After downloading and flashing newest software (NHL4 v.5.52) everything was ok. |
06-12-2004, 00:38 | #12 (permalink) |
Crazy Poster Join Date: Aug 2001
Member: 5855 Status: Offline Thanks Meter: 2 | Hi! I had the same problem with one 3100. It was version 5.02 and I downgrade it to ver. 3.10. result "Phone dead". I tried to flash the phone with Tornado...but no result. I resolve the problem with Prodigy. After the MCU writing just boot the phone manual by pressing the ON/OFF button, and the process of writing the Content Pack is starting. This operation must be done verry quick. The same step must be done when the Content Pack is finish or start to flash PPM only. This solution worked for me 100%. Regards, Claudiu. PS: Please escuse my english. |
04-19-2005, 20:30 | #13 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have a 3120 which is dead after water damaged , i cleaned it , i can flash the set .. but the set cant be switched on/// when i try to get into NORMAL MODE with tornado and i press the power switch all the LED's glow with some bright on the Display also but nothing is shown in the dispaly/// help me .. thanks Last edited by gsmsikar; 04-19-2005 at 21:16. |
04-19-2005, 21:20 | #15 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | can u give me any link , i didnt got that ..solution.. if u are talking about this , http://forum.gsmhosting.com/vbb/showthread.php?t=170529 then in the post it says that this solution is not for 3100.. |
k310i dead but flashing ok | .::ricky rayya::. | Cruiser Suite | 3 | 02-25-2008 10:37 |
T630 Dead but flash ok | rajiv007 | Cruiser Suite | 4 | 05-26-2007 17:30 |
T610 dead but flashing ok | roberts | Sony Ericsson Hardware Repair | 15 | 09-02-2006 05:00 |
T2288 dead but flashing ok | Porter | Sony Ericsson Hardware Repair | 1 | 08-17-2003 11:07 |
3310 and 8210 dead, but flashed OK... | CellM@n | Nokia Hardware & Hardware Repair | 7 | 05-27-2002 23:35 |
