09-12-2006, 19:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | 6610 Dead-flashing Ok-still Dead I HAVE A 6610 DEAD.IT SHOWS FOLLOWING ERROR MESSAGE WHEN FLASH MCU,PPM,CNT 1st Boot Ok, DCT4, UPP: 1120 FlId Aliasing with: 00EC22F0 Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 84E4269B62D281ACE09E582F6F Decoded MSID: 80B0BAE9-008434F4-AA000000 Encoded FAID: FDCE7391-1C7CA93F-DD36CCD3 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0157FFFF Erased, Time: 01:00 Area3: 0x016B0000-0x017EFFFF Erased, Time: 00:13 Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:40 Area1: 0x01580000-0x016AFFFF Erased, Time: 00:12 CNT Flashing Completed, Time: 00:03 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile SO IN NEXT STEP I FLASHED USING PPM ONLY SELECTED.ITS OK 1st Boot Ok, DCT4, UPP: 1120 FlId Aliasing with: 00EC22F0 Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 842281B4162BE97F249A911991 Decoded MSID: 80B0BAE9-008434F4-A9000000 Encoded FAID: 069B9FAA-7E08FA12-37B0A20F Area1: 0x01580000-0x016AFFFF Erased, Time: 00:12 PPM Flashing Completed, Time: 00:06 Flashing Completed, Rebooting Mobile BUT SET STILL IN DEAD.I THINK IT IS HAEDWARE PROBLEM.HOW I PROCEED TO ON MY 6610 THANK U |
09-12-2006, 19:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | after flashing if your phone is still deadjust do it like shown in the picture........it will be alive again....... chek and post result.... |
09-13-2006, 04:40 | #3 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223959 Status: Offline Thanks Meter: 8 | i m having the same problem in 6610i i tried to do like this but the points u told to connect with jumper r showing ground in my phone so whats the need of making the jumper over here. try to solve my problem i will be very thankful to u all |
09-13-2006, 05:22 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: philippines
Member: 227689 Status: Offline Thanks Meter: 24 | i have same problem like yours and i solve it may be your phone is recondition try to flash it with 6220 ver6.34 and your phone is alive again post me the result |
09-17-2006, 14:01 | #8 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
Ur phone isn't flashing OK !!!! If before flashing it, ur phone 's working then u try to use oldest or latest version Firmware and full flash again, ur phone will be alive ! B.R VinhHai | |
09-17-2006, 14:51 | #9 (permalink) |
Junior Member Join Date: Apr 2006
Member: 266915 Status: Offline Thanks Meter: 0 | 6600 white sream i have a problem like that . it was 6600 nokia:flash ok, but still white screem after some sec. it will go off .i tried to change the scream it was the same white ,but when i tried the new scream on another 6600 it worked. while my own scream was showing still white on another phone. i wonder if someone know the solution. thanks Last edited by ikeh sunday; 09-17-2006 at 14:58. Reason: bad spellings |
09-18-2006, 01:43 | #10 (permalink) | |
Member: 227689 Status: Offline Thanks Meter: 24 | Quote:
09-18-2006, 04:06 | #11 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Indonesia-Banjarmasin Age: 44
Member: 141854 Status: Offline Thanks Meter: 19 | Quote:
Have you problem is"extract content Faild" extract content needed "local mode". your phone cant local mode, Replace upp,flash again.....Good luck BR | |
02-03-2007, 17:09 | #15 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Pakistan Age: 46
Member: 62911 Status: Offline Thanks Meter: 156 | my nokia 6610 restarting with sim i flashe the phone with diffrent version but problem still here ?????????????????????????????????????????????????? ?????? any solution please |
7610 dead,flashing ok,still dead | Vcell | WD2 & APE (Symbian Phones) | 2 | 08-10-2008 11:57 |
Sgh E600 Dead-flashing Ok-still Dead | zonetrichur | Trident/AGERE Platform | 6 | 01-06-2007 15:48 |
2600 flashing ok-still dead | zonetrichur | MT-BOX | 3 | 11-30-2006 18:48 |
6630 Dead-flashing Ok-still Dead | zonetrichur | Nokia Hardware & Hardware Repair | 4 | 11-22-2006 05:54 |
6610 Dead-flashing Ok-still Dead | zonetrichur | UFS2 + UFS3-Tornadoflasher | 6 | 09-20-2006 12:27 |
