Old 03-05-2005, 09:37   #1 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
6610 keypad not working ? help me
Hi ! I have a 6610 nokia no key in the keypad is working I have checked the volume buttons but the problem is that small ic near key pad connectors I think it is called Matrix ic is not there, some one have removed it, is there any solution to bypass that ic and make jumpers to work the keypads again
The Following User Says Thank You to amitks_in For This Useful Post:
Old 03-05-2005, 10:01   #2 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
Theres no other solution - you must replace the small IC.
The Following User Says Thank You to juht For This Useful Post:
Old 03-05-2005, 10:09   #3 (permalink)
Ciubaka's Avatar
Member: 42304
Thanks Meter: 12
you can replace that glass ic with one from nokia 8310! it works 100%
The Following User Says Thank You to Ciubaka For This Useful Post:
Old 03-05-2005, 10:50   #4 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
Sir any other Ic matchses with 6610 model ? cause I dont have 8310 ic
Old 03-05-2005, 11:04   #5 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
I have placed the Ic from a dead 6610 board but still no button is functioning plz help
Old 03-05-2005, 15:39   #6 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
Are you 100% sure that the IC correct installed?
IF yes, then next step is try one more chip, then check UEM and CPU.
This class chip is used on many dct4 phones. All are the same.
Old 03-07-2005, 05:30   #7 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
check volume switch or change it.
The Following User Says Thank You to DeltaGSM For This Useful Post:
Old 04-12-2005, 19:07   #8 (permalink)
Member: 65714
Thanks Meter: 17
i replace volume switch, replace EMI keypad. but keypad not work at all. What should i do?
The Following User Says Thank You to 354boyo For This Useful Post:
Old 09-15-2009, 16:43   #9 (permalink)
Member: 440255
Thanks Meter: 6
dear 6610 ka menu butan aor exit butan kaam nahe kar rahe . pls give the salution if u know.
W350i keypad not working help me palav Sony Ericsson Hardware Repair 4 06-06-2011 05:59
j700 keypad not working ...help me kadour83 Samsung Hardware Repair 0 01-27-2010 21:09
3500c keypad not working help me plz shani72 Nokia Hardware & Hardware Repair 1 09-04-2009 14:11
nokia 2600c keypad not working help me palav Nokia Hardware & Hardware Repair 0 08-25-2009 19:33
6610 keypad not working.. one part is missing broken_rules Nokia Hardware & Hardware Repair 0 09-17-2008 14:50
Page generated in 0.19100 seconds with 9 queries
