07-18-2004, 10:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | 6610 not charging i have 6610 not charging. i reball perfect uem btu no solution. must change uem ?? or if i take uem from other 6610 & fit in this 6610 , possible ???????? b.r. akki |
The Following User Says Thank You to akshay For This Useful Post: |
07-18-2004, 12:54 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | check voltages on battery point..trace any resistor with shifted values, check lines, maybe UEM faulty if lines ok WBR Syed |
The Following User Says Thank You to Syed For This Useful Post: |
07-19-2004, 21:29 | #4 (permalink) |
Member: 18057 Status: Offline Thanks Meter: 64 | no dear this is not solution. anyway thanx for reply. u know ? how to direct 3.6 v. without any prob... mean not display shows not charging but bat.. possible to fillup. b.r. akki |
07-19-2004, 21:41 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Just look in the service manual! There is a step by step repair guide for your problem! |
The Following User Says Thank You to Chris02 For This Useful Post: |
07-20-2004, 00:07 | #7 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | The Fuse is the problem in the most cases! But no in all! So sometimes you also have to look in SM! |
07-20-2004, 18:55 | #8 (permalink) | |
Member: 18057 Status: Offline Thanks Meter: 64 | Quote:
so why dont explain your exprince in forum for help , to other . if u like to give help in private so pls..... mail on [email protected] thanx . b.r. akki | |
07-21-2004, 01:15 | #9 (permalink) | |
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
07-21-2004, 03:28 | #10 (permalink) |
Freak Poster Join Date: Mar 2003 Location: nederland Age: 52
Member: 24929 Status: Offline Thanks Meter: 7 | thank you chris02, i think that the solution works but when you don't try why you say no dear this is not solution. anyway thanx for reply. |
The Following User Says Thank You to gsm_style For This Useful Post: |
07-21-2004, 19:45 | #11 (permalink) |
Member: 18057 Status: Offline Thanks Meter: 64 | @gsm style i mean to say if fuse is not ok. so its not possible to display show you not charging. { perticular word NOTACHARGING ] if charger surrent passed in circuit then it says not chraging. or fuse work is only pass charger current. thats all ya but not show u anything then i also conform fuse only. b.r. akki |
07-21-2004, 23:14 | #12 (permalink) |
Member: 24929 Status: Offline Thanks Meter: 7 | if the fuse not work and you put charger into the phone then after a few seconds you can see the error message phone not charging in the display |
07-24-2004, 10:41 | #13 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | @all is phone shwoing"not charging" then" 1.if you connect charger and imidiately write "not charging" then write new PMM values. 2. if you connect charger and after 2 or 3 seconds write "not charging" the check charging connector,battery connector(broken pins),fuse(if you measure will show ok,but the wire inside is not good because is "half burned"),coil after fuse,thermal resistor"R22"(the big one) and finaly uem. good luck |
The Following 3 Users Say Thank You to Platijet For This Useful Post: |
6610 not charging/keypad stuck | teensurfer | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-23-2008 10:34 |
6610 not charging | juniour member | Nokia Hardware & Hardware Repair | 3 | 07-18-2007 20:05 |
6610 no charge | ghba | Nokia Hardware & Hardware Repair | 4 | 04-29-2005 23:22 |
Hello anybody, my Nokia-3210 is not charging it is showing not charging | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-25-2003 11:27 |
