Old 09-01-2007, 17:30   #1 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
Unhappy 6610i auto off after 20 sec
6610i Imei Damaged but i write RPL files and write IMEI now its Signal ok but after 20 seconds it being auto off if someone has it solution than please share me
i m in trouble
i ll be thankfull
Old 09-02-2007, 08:37   #2 (permalink)
..::ARUN::..'s Avatar
Member: 566335
Thanks Meter: 156
1) change battery
2) check shotage betwwen positive & negative
3) full flash with latest version then write a good pm & apply ui settings
4) change rtc
Old 09-02-2007, 08:45   #3 (permalink)
willydewi's Avatar
Member: 331835
Thanks Meter: 64
UEM or Power ic broken ...change it bro and write rpl ,flash again and then unlock ..good luck ...
Old 09-02-2007, 09:09   #4 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,847
i think you had pached the imei file from mcu it causes that uem damage and off within 33 second
Old 09-02-2007, 09:09   #5 (permalink)
simonng83's Avatar
Member: 85444
Sonork: 100.114343
Thanks Meter: 3,217
i m in trouble
i ll be thankfull
problem is on yr hardware UEM power ic!
Old 09-02-2007, 10:48   #6 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
how can i repair UEM or POwer ic
please guide me throw picture or diagram
Old 09-02-2007, 11:35   #7 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 281
this is 100% uem problem. u have to replace uem and write it
M A Sabah
Malappuram
Old 09-02-2007, 11:57   #8 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
sir this problem is runing before patch Imei file from mcu
Old 09-02-2007, 12:02   #9 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
how can i change UEM or Power ic please make understand me throw pic or diagram
i ll b thankfull u
Old 09-02-2007, 12:33   #10 (permalink)
tabuki's Avatar
Member: 455665
Thanks Meter: 36
friend, replace your UEM! read UEM first before replacing w/ new one, after replacing UEM full flash then write it back-up rpl then unlock
Old 09-02-2007, 13:03   #11 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
MCU ID: 0x1120
Sending algo...
Algo is ready...
P-key nokia module version 01.00
Reading...
UEM IMEI: 31700500497096X
ok
Old 09-03-2007, 14:37   #12 (permalink)
Member: 566610
you better replace uem bro............after u replace a gud one,just write rpl !
nokia 1100 auto off after 30 sec chhoton Nokia Hardware & Hardware Repair 19 11-25-2014 15:46
1110 auto off after 5 sec kapilgupta Nokia Hardware & Hardware Repair 16 06-23-2011 09:06
6610i insert sim and auto off after 20 sec GSMBALOCH Nokia Hardware & Hardware Repair 14 09-03-2007 18:55
2600 Auto Off After 30 Sec sharaz191 Nokia Hardware & Hardware Repair 11 06-25-2007 12:15
SL55 when Dor is open phone worked IF closed powered off after 20 sec solution MaFiaaa Siemens Hardware Repair Area 7 02-27-2005 20:21
Page generated in 0.50681 seconds with 8 queries
