6610i not charging hey guyz i have 6610i which displays not charging immediately after inserting charging pin.i have occured same problem with 3100.But no solution for that.. PLz help me Battery, charger,charging connector is OK Resoldered K fuse but no soln.. Thanx in advance |
it is so easy .... just change the UEM ic ( tested 100% ) |
HI MAN yes pirate 1000% correct but before you DECIDE to change uem i SUGGEST you to REBALL or rework with flux this might just save u some xtra $$$ keeep well bye : |
sorry but, where can i find this UEM IC... |
hi , max232 chip its always fail just in not charging problem & not advisable !!!!..... |
max232????? what's that chip has to do with charging :D |
hi azampk : its ma be success by your good luck !!!! |
1 Attachment(s) no no no what are you doing? the only thing you change are F100 and that's all, see picture |
6610i not charging 6610i not charging is not flash?????????? |
question after that? mmm change uem?? is rpl is just same like other?? ( 8310) |
thanks goog work go ahead |
:) change uem your problem maybe ok try it agian and agian ok best of luck;).......................................ok |
