Old 04-15-2007, 16:24   #1 (permalink)
Member: 372160
Thanks Meter: 11
6610i TEST MODE
HELP ME frends
6610i is not water dimage and other but TEST mode
i do UI and flash complet done.
help me speedly please
The Following User Says Thank You to didarilm For This Useful Post:
Old 04-15-2007, 16:39   #2 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
Check the connections of the middle pin of the battery connectors and its connected components
Old 04-15-2007, 16:40   #3 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
Re heat the uem it will be ok.
Old 04-15-2007, 20:40   #4 (permalink)
Member: 372160
Thanks Meter: 11
i do re heat the UEM but fone dimaged (turned off)
Old 11-26-2007, 12:39   #5 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Originally Posted by didarilm View Post
HELP ME frends
hi.. i have a6610i that water damaged.. and now in test mode.. is thre any solution...?
thanx..
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware Repair 14 07-11-2011 05:49
6610I test mode Adityaram Nokia Hardware & Hardware Repair 6 07-30-2010 08:15
6610i local and test mode doodmt Nokia Hardware & Hardware Repair 1 10-21-2009 13:51
6610i local and test mode sebY7676 Nokia Hardware & Hardware Repair 3 10-15-2009 19:49
Test mode, Local mode Normal mode royke Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-13-2002 11:33
Page generated in 0.15066 seconds with 9 queries
